[pgrouting-dev] Weekly Report (Week 2) for pgRouting Project - Extension of pgRouting Contraction framework to implement Contraction By Area
Ankur Shukla work.ankurshukla at gmail.com
Sun Jun 11 09:58:36 PDT 2017
Hi All Community Members,
This is Ankur Shukla. The following is the weekly report for my project for
Week 2 (June 6 - June 12):
*What did you get done this week?*
I worked upon modifying the code generated in the last week. I modified the
output parameters of the template code and the driver of the C++ code. I
also improved my understanding of the existing contraction framework with
the help of my mentor.
Details can be found in [1].
Set of pull requests can be found in [2].
*What do you plan on doing next week?*
I plan to improve the code of the new function and also implement pgTap
tests in the next week.
Details of possible sub tasks can be found in [3]
*Are you blocked on anything?*
This week I did not face any blocking issue.
The wiki page can be found in [4]
The repository can be found in [5]
[1] *https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-2-tasks
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-2-tasks>*
[2] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Ar
ea-Contraction#my-contributions
[3] *https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-2
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-2>*
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction
[5] https://github.com/pgRouting/pgrouting/tree/gsoc/areaContraction
Regards.
*Ankur Shukla*
Teaching Assistant, Centre of Studies in Resources Engineering
Company Coordinator, Placement Cell
IIT Bombay
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20170611/47c90d0a/attachment.html>
More information about the pgrouting-dev mailing list
