[pgrouting-dev] Weekly Report (Week 3) for pgRouting Project - Extension of pgRouting Contraction framework to implement Contraction By Area
Ankur Shukla
work.ankurshukla at gmail.com
Sun Jun 18 08:41:31 PDT 2017
Hi All Community Members,
This is Ankur Shukla. The following is the weekly report for my project for
Week 3 (June 13 - June 19):
*What did you get done this week?*
This week I started with coding the pgr_areaContraction function logic. I
built a skeleton code for the same. I also wrote some tests and started
writing the documentation for the code and my proposal.
Details can be found in [1].
Set of pull requests can be found in [2].
*What do you plan on doing next week?*
I plan to complete the code for pgr_areaContraction function along with the
documentation and test.
Details of possible sub tasks can be found in [3]
*Are you blocked on anything?*
This week I did not face any blocking issue.
The wiki page can be found in [4]
The repository can be found in [5]
[1] *https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-3-tasks
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-3-tasks>*
[2] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Ar
ea-Contraction#my-contributions
[3] *https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-3
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction#week-3>*
[4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Area-Contraction
[5] https://github.com/pgRouting/pgrouting/tree/gsoc/areaContraction
Regards.
*Ankur Shukla*
Teaching Assistant, Centre of Studies in Resources Engineering
Company Coordinator, Placement Cell
IIT Bombay
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20170618/9c83c580/attachment.html>
More information about the pgrouting-dev
