[pgrouting-dev] GSoc'17 Weekly Report 4 - Rewrite of Turn Restricted Shortest Path Algorithm in pgRouting
vidhan jain vidhanj1307 at gmail.com
Sun Jun 25 08:10:10 PDT 2017
Hi everyone,
   1.
   What did you get done this week?
   This week, I created pgr_dijkstraTRSP.hpp file which will hold the main
   logic of the dijkstraTRSP. In certain scenarios, the result returned by
   dijkstra may not contain restriction. I had also implemented the logic to
   determine whether the result returned by dijkstra contains a turn
   restriction.
   - Details can be found in [1]
      - Set of pull requests can be found in [2]
   2.
   What am I going to achieve for next week?
   I'll be implementing the functionality to convert a given graph into its
   corresponding Line graph in the coming week.
   Details of possible sub tasks can be found in [3]
   3.
   Is there any blocking issue?
   Currently, I am not blocked on anything.
   - The wiki page can be found in [4]
      - The repository can be found in [5]
   [1]
   https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#first-evaluation-period
   [2]
   https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP/#log-of-pull-requests
   [3]
   https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP#official-coding-period-phase-2june-27---july-24
   [4] https://github.com/pgRouting/pgrouting/wiki/GSoC-2017-Rewrite-TRSP
   [5] https://github.com/pgRouting/pgrouting/tree/gsoc/rewritetrsp
Best of luck everyone for the next week.
Thanks,
Vidhan Jain
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20170625/69be5c54/attachment.html>
More information about the pgrouting-dev mailing list
