[pgrouting-dev] Releasing pgRouting, osm2pgRouting and pgRoutingLayer
Vicky Vergara vicky at georepublic.de
Thu Oct 12 14:30:50 PDT 2017
Hello all:
pgROuting Team is pleased to announce 3 releases:
pgRouting version 2.5.1
osm2pgrouting version 2.3.0
pgRoutingLayer version 2.2.0
See details bellow
regards.
pgRouting Team
To see the issues closed by this release see the Git closed milestone for
2.5.1
<https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%202.5.1%22%20>
on Github.
Bug fixes
   - Fixed prerequisite minimum version of: cmake
Can be downloaded from [1]
Documentation can be found on [2]
[1] https://github.com/pgRouting/pgrouting/releases/tag/v2.5.1
[2] http://docs.pgrouting.org/2.5/en/index.html
To view the full list of issues:
https://github.com/pgRouting/osm2pgrouting/pulls?utf8=%E2%9C%93&q=milestone%3A%22osm2pgrouting%202.3.0%22%20
Main changes are:
   - Cost should not return the same value
   - Added a points of Interest table
   - Some default one_way values are taken into consideration
   - Relations are also considered
   - New mapconfig_for_pedestrian.xml
New Flags
--attributes Include attributes information.
--tags Include tag information.
--chunk arg (=20000) Exporting chunk size.
--no-index Do not create indexes (Use when indexes are already created)
Can be downloaded from [3]
Documentation can be found on [4]
Sorry I haven't got time to update it but its basically the same as on:
https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.2
[3] https://github.com/pgRouting/osm2pgrouting/releases/tag/v2.3.0
[4] https://github.com/pgRouting/osm2pgrouting/wiki/Documentation-for-osm2pgrouting-v2.3
On QGIS plugins, select pgRoutingLayer and click on "upgrade Plugin"
Documentation can be found on [5]
Whith this release of pgRoutingLayer
   - BBOX is optional
   - Supports pgRouting v2.0 up to v2.5
   - Menu shows non deprecated functions of the corresponding version only.
[5] https://github.com/pgRouting/pgRoutingLayer/wiki/Documentation-v2.2
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20171012/2f916244/attachment.html>
More information about the pgrouting-dev mailing list
