[pgrouting-dev] [SoC][pgRouting] GSoC'18 Week 12- Implement bellmanFord, dagShortestPath and parallel-Dijsktra in pgrouting
Sourabh Garg
sourabh.gargcd.mat14 at iitbhu.ac.in
Sun Aug 5 13:21:56 PDT 2018
Hi all,
This is my report for week 12(July 30 - Aug 5).
*What did you get done this week?*
- Check and Fix issues related to new functionalities
- Make the code compatible with some changes in develop branch
- Merged work from all project branches to the develop branch
- Write a Google presentation about this project [5]
Details of PR can be found at [1]&[2].
*What do you plan on doing next week?*
- Create a final report page and finish the final evaluation.
- Work on the presentation to amend some changes.
*Are you blocked on anything?*
No
The project's wiki page and Tag can be found at [3] and [4] resp.
[1]. https://github.com/pgRouting/pgrouting/pull/1078
[2]. https://github.com/pgRouting/pgrouting/pull/1082
[3].
https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford
<https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Parallel-Dijkstra-and-Bellman-Ford>
[4]. https://github.com/pgRouting/pgrouting/releases/tag/gsoc2018-codeSG-lw
[5].
https://docs.google.com/presentation/d/1ESngDemJKLmvWCO6uisd1bmhXGYdjc5ERa-ZEWdqOx0/edit#slide=id.g35f391192_00
Best Regards,
Sourabh Garg
IIT(BHU), India
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180806/6a8099d6/attachment.html>
More information about the pgrouting-dev
