[pgrouting-dev] [SoC] [GSoC 2018] Final Report - Implement Minimum cost flow and ChPP for pgRouting
Maoguang Wang
xjtumg1007 at gmail.com
Sun Aug 19 11:10:24 PDT 2018
Hi all,
I am Maoguang Wang, and This is my final report for my GSoC project.
*Title: Implement Minimum-cost flow Algorithm by the Boost Graph Library
and Chinese Postman Problem for pgRouting *
*Organization: *pgRouting under OSGeo
*Abstract: *
Minimum-cost flow problem is an extension of maximum flow problem with an
added cost (per unit flow) for each edge. The Chinese Postman Problem
(ChPP) in a directed graph can be solved by Minimum-cost flow algorithm.
I have added Minimum-cost flow algorithm and directed ChPP algorithms to
pgRouting during this GSoC period.
*Implemented functions:*
* pgr_ChPP*
- pgr_ChPP_Cost
- pgr_minCostMaxFlow
- pgr_minCostMaxFlow_Cost
*State of the art before the project: *pgRouting didn't have above
functionalities before my GSoC.
*Addition that my project brought to pgRouting: *
*The deliverables are code, full documentation, documentation tests, pgTap
of above functions.*
* Future Directions: *
- Double confirm the documentation.
- Implement undirected ChPP algorithms.
- Implement windy or other complex ChPP problems.
- Test the implementation in real cases.
*Links:*
- *Wiki: *
https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-Minimum-cost-flow-and-ChPP
- *Last Pull Request:* https://github.com/pgRouting/pgrouting/pull/1077
- *Slide: *
https://docs.google.com/presentation/d/1WsnhuOhcsl_SADo3AO8VFO3hIAXuLxIHhrGsAMDfOKY/edit?usp=sharing
- *Tag:* https://github.com/pgRouting/pgrouting/tree/gsoc2018-XJTUmg-lw
Best Regards,
Maoguang Wang
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180820/b50c4ad0/attachment-0001.html>
Name: pgRouting Directed Chinese Postman.pdf
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180820/b50c4ad0/attachment-0001.pdf>
More information about the pgrouting-dev
