[pgrouting-dev] Issue regarding Segmentation Fault: Signal 11
Sourabh Garg
sourabh.gargcd.mat14 at iitbhu.ac.in
Wed Jun 6 14:26:24 PDT 2018
Hi all,
I am presently working under GSoC'18, for the project titled "Implementing
Bellman-ford and Parallel Dijkstra for pgrouting". I have
successfully created a function named pgr_bellman_ford which works for one
source to one target parameters inputs[4]. Later, I have transformed the
pgr_bellman_ford function for all variants, by understanding from the
existing pgr_dijkstra function in PR[1], but it is resulting in some
errors[3], which I am not able to figure out. Please review my PR' s
commit[2]. On debugging from Postgres logs trace in src files(.c and .cpp
files), I found that it is giving segmentation fault: signal 11.(see
Attached postgres_log_trace.jpg). Please help me with this issue.
[1]. https://github.com/pgRouting/pgrouting/pull/1039
[2]. https://github.com/pgRouting/pgrouting/pull/1039/commits/
ab0f29a2533a985ea842e03109e28fc670eebb5e
[3]. https://files.gitter.im/codeSG/uxCI/image.png
[4].
https://github.com/pgRouting/pgrouting/pull/1039/commits/3e599d45b8b07d79ad1886faf08da17f5af8cae4
Thanks,
Sourabh Garg
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180607/b639195a/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180607/b639195a/attachment-0001.jpe>
More information about the pgrouting-dev
