[pgrouting-dev] GSoc'18 Week 04 Report - Implement MST and Mincut
Aditya Pratap Singh adityapratap.singh28 at gmail.com
Sat Jun 9 21:14:32 PDT 2018
Hello All,
This is my report for week 4 (June 4 - June 10).
*What did you get done this week?*  I added pgTAP for pgr_prim and refining
signature, column names and output results.
Detailed can be found here [1] and PR can be found here [2].
*What do you plan on doing next week?*
  * I'll add the functionality of multiple root_vertex and then start with
kruskal algorithm.
*Are you blocked on anything?*
No, at the moment I’m not blocked.
The wiki page can be found in [3]
The repository can be found in [4]
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-
MST-and-Mincut#week-4
[2] https://github.com/pgRouting/pgrouting/pull/1041
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-MST-and-Mincut
[4] https://github.com/pgRouting/pgrouting/tree/gsoc/mincut
Regards,
Aditya Pratap Singh
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180610/593b7613/attachment-0001.html>
More information about the pgrouting-dev mailing list
