[pgrouting-dev] GSoc'18 Week 06 Report - Implement MST and Mincut
Aditya Pratap Singh adityapratap.singh28 at gmail.com
Sun Jun 24 05:18:21 PDT 2018
Hello All,
This is my report for week 6 (June 18 - June 24).
*What did you get done this week?*   Implemented the kruskal algorithm and
then add the connected component to get the minimum spanning tree of each
subgraph.
Detailed can be found here [1] and PR can be found here [2].
*What do you plan on doing next week?*
  * Refine signature and add test, documentation and pgTAP.
*Are you blocked on anything?*
No, at the moment I’m not blocked.
The wiki page can be found in [3]
The repository can be found in [4]
[1] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-MS
T-and-Mincut#week-6
[2] https://github.com/pgRouting/pgrouting/pull/1051
[3] https://github.com/pgRouting/pgrouting/wiki/GSoC-2018-MST-and-Mincut
[4] https://github.com/pgRouting/pgrouting/tree/gsoc/mincut
Regards,
Aditya Pratap Singh
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20180624/331f7715/attachment.html>
More information about the pgrouting-dev mailing list
