[pgrouting-dev] pgRoutingLayer QGIS3 version
Worth Lutz wal3 at mindspring.com
Fri Oct 12 08:34:15 PDT 2018
I agree with using a linter also.
Editorconfig just helps reduce the output of the linter.  :)
*Worth Lutz*
On 10/12/2018 4:31 AM, Cayetano Benavent wrote:
> Hi,
> We are already using editorconfig in pgRoutingLayer:
> https://github.com/pgRouting/pgRoutingLayer/blob/master/.editorconfig
> I propose to use PyLint in addition to editorconfig, because the first
> is a code analysis tool. Editorconfig, as far as I know, is a tool
> to maintain consistent coding styles between different editors.
> Thanks,
> *Cayetano Benavent
> *Head of Data
> +34 954 095 876 <tel:%2B34%20954%20095%20876>
> www.geographica.gs <http://www.geographica.gs/>
> El jue., 11 oct. 2018 a las 21:32, Vicky Vergara
> (<vicky at georepublic.de <mailto:vicky at georepublic.de>>) escribió:
>     Yes,
>     good idea, many editors use that .editorconfig file
>     On Thu, Oct 11, 2018 at 12:51 PM Worth Lutz <wal3 at mindspring.com
>     <mailto:wal3 at mindspring.com>> wrote:
>         This may be helpful for the project. https://editorconfig.org/
>         Take a look and see if it will help keep coding in the project
>         consistent.
>         I have no connection with editorconfig except that I use it.
>         *Worth Lutz*
>         On 10/11/2018 1:06 PM, Cayetano Benavent wrote:
>>         Hi Vicky,
>>         Python has several linters. I propose to use for
>>         pgRoutingLayer project this tool: PyLint
>>         (http://pylint.pycqa.org). PyLynt is mantained by Python Code
>>         Quality Authority (http://meta.pycqa.org). I need to prepare
>>         and include a configuration file (.pylintrc) in repository.
>>         To test this new release I will write a wiki explaining how
>>         can you do it.
>>         Thanks,
>>         *Cayetano Benavent
>>         *Head of Data
>>         El mié., 10 oct. 2018 a las 15:44, Vicky Vergara
>>             Hi Cayetano
>>             Does python has some sort of code linter?
>>             Would be nice to lint the code and set some standards,
>>             like use spaces instead of tabs, how many spaces, etc.
>>             I am not a python expert but for C++ I use googles linter:
>>             https://github.com/cpplint/cpplint
>>             BTW, what do I have to do to test the the release?
>>             Regards Vicky
>>             On Wed, Oct 10, 2018 at 3:10 AM Cayetano Benavent
>>             <cayetano.benavent at geographica.gs
>>             <mailto:cayetano.benavent at geographica.gs>> wrote:
>>                 Hi all,
>>                 I have merged PR#82
>>                 <https://github.com/pgRouting/pgRoutingLayer/pull/82>
>>                 and published the new pre-release "v3.0.0-alpha1":
>>                 https://github.com/pgRouting/pgRoutingLayer/releases/tag/v3.0.0-alpha1
>>                 I know we need to do more work but I have little time
>>                 and I think priority is to have a QGIS3 version to
>>                 share with community.
>>                 More things: I would like to update the Readme file
>>                 because it is totally outdated.
>>                 Thanks!
>>                 *Cayetano Benavent
>>                 *Head of Data
>>                 El jue., 4 oct. 2018 a las 12:44, Cayetano Benavent
>>                 (<cayetano.benavent at geographica.gs
>>                 <mailto:cayetano.benavent at geographica.gs>>) escribió:
>>                     Hi all,
>>                     Works I have done:
>>                     - I've updated develop branch because it was very
>>                     outdated (now is paired with master).
>>                     - I've changed base branch (now is develop) for
>>                     PR to merge all the works for QGIS3 version:
>>                     - I've created "gsoc2018" tag with all the works
>>                     derived from GSOC 2018 by Aasheesh Tiwari past
>>                     summer:
>>                     https://github.com/pgRouting/pgRoutingLayer/tree/gsoc2018
>>                     In several days we remove python3 branch, we will
>>                     merge PR#82
>>                     and we will create v3.0.0-alpha1 version (without
>>                     pgr_DijkstraCost).
>>                     Regarding to DijkstraCost function, I will try to
>>                     review it again to include in v3.0.0-alpha2
>>                     version (now I understand his utility in QGIS :) ).
>>                     It is important understand several things to do a
>>                     better planning of pgRoutingLayer future:
>>                     - QGIS2 is developed entirely with Python 2.
>>                     - QGIS3 is developed entirely with Python 3 and
>>                     PyQGIS API is very different to QGIS2.
>>                     - Python 2 EOL (end of life) is very near (Python
>>                     2 will be retired in 1 year)
>>                     (https://pythonclock.org/ and
>>                     https://www.python.org/dev/peps/pep-0373/).
>>                     Taking in consideration this information we
>>                     should not spend time to code in Python 2 so we
>>                     only can develop in one direction: QGIS3.
>>                     Last pgRoutingLayer version for QGIS2 should be
>>                     2.2 (actually this is the last version uploaded
>>                     to QGIS plugin hub).
>>                     QGIS3 is very (very) superior to QGIS2 (most of
>>                     his core has been rewrited) so if you can migrate
>>                     version (2 to 3) you should do. I can help you if
>>                     you do not know how to migrate version (it is
>>                     very easy in all operative systems).
>>                     We are very near to have a QGIS3 version!
>>                     Regards,
>>                     *Cayetano Benavent
>>                     *Head of Data
>>                     El mié., 3 oct. 2018 a las 17:01, Vicky Vergara
>>                         Hi Cayetano
>>                         Please Merge first the branch to "develop"
>>                         branch.
>>                         And clean the repository
>>                         send a mail to this list about the branches
>>                         that will be deleted,
>>                         wait 3 or 4 days for people to double check
>>                         that no "important" work will be deleted.
>>                         Make sure that the tag that contains the GSoC
>>                         students work was created.
>>                         (and the tag has as last commit, the last
>>                         commit of the student during the program)
>>                         I really don't remember if I taged his work,
>>                         we never continue work on a students branch,
>>                         that branch has to remain intact when the GoC
>>                         program is over that contains the students
>>                         work and his work only.
>>                         By cleaning the repo:
>>                         When people clone or update their fork, they
>>                         would only get master and develop branch.
>>                         master has pgRoutingLayer v2.2.0 and branch
>>                         develop has v3.0.0-dev
>>                         Because the version is a "major" change  we
>>                         have to go thru the following phases:
>>                         v3.0.0-alpha (v3.0.0-alpha1 if needed see bellow)
>>                         v3.0.0-beta
>>                         v3.0.0-rc
>>                         etc.
>>                         Use that versioning numberingto create the
>>                         following branches & tags
>>                         v3.0.0-alpha1  Includes all the functions
>>                         that are coded
>>                         v3.0.0-alpha2  Remove function(s) that
>>                         is(are)  well-known to have issues (issues
>>                         must be documented on the issue list)
>>                         or
>>                         v3.0.0-alpha Include only the functions that
>>                         supposedly work well
>>                         or
>>                         v3.0.0-alpha1 Includes only pgr_dijkstra
>>                         v3.0.0-alpha2 Includes also pgr_dijkstraCost
>>                         etc ...
>>                         I like third option best because also work on
>>                         documentation has to be done.
>>                         So make users documentation of pgr_dijkstra
>>                         and make the alpha with only that function
>>                         So gradually documentation and functionality
>>                         come in an alpha
>>                         I know version pgRoutingLayer v3.0.0 will use
>>                         python3 what I dont know, is which versions
>>                         of QGIS it will work.
>>                         The version v2.0 didn't handle the functions
>>                         with the "pgr_" is that going to remain the same?
>>                         Which versions of pgRouting  will it work with?
>>                         I guess you removed all the deprecated
>>                         functions, so for example, and kept for example
>>                         for 2.1: pgr_dijkstra, pgr_drivingDistance
>>                         and pgr_KSP
>>                         Maybe, many users (like me) have QGIS 2.18
>>                         Some instructions about testing the phases
>>                         would be needed.
>>                         About initial decisions of what can be included:
>>                         Now that we are starting a new major
>>                         one thing is I learned is don't include what
>>                         does not work
>>                         In our case, besides pgRoutingLayer code
>>                         correctness, we depend on the correctness of
>>                         pgRouting :
>>                         About withPoints & all proposed functions
>>                         https://docs.pgrouting.org/2.6/en/proposed.html#stable
>>                         There is a warning. and some detected issues:
>>                         https://github.com/pgRouting/pgrouting/issues?q=is%3Aopen+is%3Aissue+label%3AwithPoints
>>                         About experimental functions:
>>                         https://docs.pgrouting.org/2.6/en/proposed.html#experimental-functions
>>                         About pgr_dijkstraCost in QGiS I use it (to
>>                         generate the image) here:
>>                         https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-5-many-pedestrians-going-to-different-destinations-returning-aggregate-costs
>>                         compare VS
>>                         https://workshop.pgrouting.org/2.5.0/en/chapters/shortest_path.html#exercise-4-many-pedestrians-going-to-different-destinations
>>                         It gives a different perspective of the
>>                         results of pgr_dijkstra
>>                         As reference:
>>                         This is the latest pgRouting documentation
>>                         https://docs.pgrouting.org/2.6/en/index.htm
>>                         This is the pgRouting 3.0.0-dev documentation
>>                         (to be released on September 2019)
>>                         https://docs.pgrouting.org/dev/en/index.html
>>                         Lots of things to plan
>>                         Regards
>>                         Vicky
>>                         On Tue, Oct 2, 2018 at 7:32 PM Cayetano
>>                         Benavent <cayetano.benavent at geographica.gs
>>                             Hi all,
>>                             I have finally cleaned code and fixed
>>                             last bugs in python3 branch from
>>                             pgRoutingLayer with all the work done by
>>                             student Aasheesh Tiwari (@AasheeshT) this
>>                             summer in GSOC.
>>                             I would like to merge python3 branch with
>>                             master and upload a QGIS3 version. I've
>>                             tested this code and it is working well
>>                             in QGIS3 although there is still a lot of
>>                             work to do :)
>>                             It is important to note that I've removed
>>                             several functions (what I really did is
>>                             comment access from GUI):
>>                             - WithPoints family: these functions
>>                             don't work well because they were a very
>>                             last addition in GSOC. We will add this
>>                             code when Aasheesh (or somebody) fixes them.
>>                             - TSP euclidean: This function is not
>>                             working properly (before GSOC this
>>                             function does not work well). I think is
>>                             more useful to add pgr_TSP in the future
>>                             that fix euclidean version.
>>                             - DijkstraCost: This function is not
>>                             working properly and I don't undestand
>>                             very well the purpose of this function in
>>                             QGIS.
>>                             Deprecated functions were also removed
>>                             (kdijkstra_path and kdijkstra_cost) but
>>                             in this case we removed all the code.
>>                             Thanks,
>>                             *Cayetano Benavent
>>                             *Head of Data
>>                             www.geographica.gs
>>                             _______________________________________________
>>                             pgrouting-dev mailing list
>>                             pgrouting-dev at lists.osgeo.org
>>                             <mailto:pgrouting-dev at lists.osgeo.org>
>>                             https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>                         Georepublic UG (haftungsbeschränkt)
>>                         Salzmannstraße 44,
>>                         81739 München, Germany
>>                         Vicky Vergara
>>                         Operations Research
>>                         eMail: vicky at georepublic.de <http://georepublic.de>
>>                         Web:https://georepublic.info
>>                         Tel: +49 (089) 4161 7698-1
>>                         Fax: +49 (089) 4161 7698-9
>>                         Commercial register: Amtsgericht München, HRB 181428
>>                         CEO: Daniel Kastl
>>             Salzmannstraße 44,
>>             Vicky Vergara
>>             Operations Research
>>             CEO: Daniel Kastl
>     Salzmannstraße 44,
>     Vicky Vergara
>     Operations Research
>     CEO: Daniel Kastl
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181012/13ff9536/attachment-0001.html>
More information about the pgrouting-dev mailing list
