[pgrouting-dev] AssertFailedException: false (2.6.1)
Vicky Vergara
vicky at georepublic.de
Wed Oct 31 16:24:08 PDT 2018
Can you open an issue.
Include a link to the data where it fails.
Make the data as small as possible, please.
I need to reproduce the problem.
Thanks
Vicky
On Wed, Oct 31, 2018 at 5:06 PM Spencer Gardner <spencergardner at gmail.com>
wrote:
> I recently installed a new server with Ubuntu 18.04.1 and pgrouting 2.6.1
> and am seeing an AssertFailedException error when I try to do a
> pgr_drivingdistance. The same calls worked on my previous build, but that
> was with a different dataset. (Same data structure, but different data)
> Is this indicative of a problem with my data? Or is this a bug related to
> 2.6.1? I can provide a sample dataset if that's helpful.
> The call I'm making is:
> SELECT
> route.node AS node_id,
> route.agg_cost
> FROM pgr_drivingdistance(
> 'SELECT * FROM "tmp_hs_net"',
> ARRAY[28143,37447,43401,50409,91800,98234,108908,1888,1897,85914,1898,85930,112714,11851,31406,37961,43534,50994,57875,71749,77860,4424,4641,35309,53002,57762,75549,79856,80019,88626,89435,116859,37736,51812,97808]::INTEGER[],
> 2680,
> equicost:=TRUE,
> directed:=TRUE
> ) route
> Full text of the error is:
> ;ERROR: AssertFailedException: false at
> /build/pgrouting-z9Xs4y/pgrouting-2.6.1/include/dijkstra/pgr_dijkstra.hpp:591
> *** Execution path***
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(_Z13get_backtraceB5cxx11v+0x3c)
> [0x7f19a7ebda5c]
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(_ZN12Pgr_dijkstraIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_14bidirectionalSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE39get_drivingDistance_with_equicost_pathsERSC_RKSt6vectorIlSaIlEERSt5dequeISF_ImSaImEESaISM_EEd+0x672)
> [0x7f19a7f129b2]
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(_ZN12Pgr_dijkstraIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_14bidirectionalSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEE29drivingDistance_with_equicostERSC_St6vectorIlSaIlEEd+0x515)
> [0x7f19a7f15665]
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(_Z19pgr_drivingDistanceIN9pgrouting5graph14Pgr_base_graphIN5boost14adjacency_listINS3_4vecSES5_NS3_14bidirectionalSENS0_12Basic_vertexENS0_10Basic_edgeENS3_11no_propertyENS3_5listSEEES7_S8_EEESt5dequeI4PathSaISE_EERT_St6vectorIlSaIlEEdbRNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEEE+0x162)
> [0x7f19a7f18bc2]
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(do_pgr_driving_many_to_dist+0x2c0)
> [0x7f19a7f0f9c0]
> [bt]/usr/lib/postgresql/9.5/lib/libpgrouting-2.6.so(driving_many_to_dist+0x342)
> [0x7f19a7f0eda2]
> [bt]postgres: 9.5/main: gis san_jose 192.168.40.232(56039)
> SELECT(ExecMakeTableFunctionResult+0x414) [0x560254af1bc4]
> SELECT(+0x218b17) [0x560254b06b17]
> SELECT(ExecScan+0xd4) [0x560254af3894]
> SELECT(ExecProcNode+0x1c0) [0x560254aec4e0]
> SELECT(standard_ExecutorRun+0x10e) [0x560254ae951e]
> SELECT(+0x306e9f) [0x560254bf4e9f]
> SELECT(PortalRun+0x300) [0x560254bf6450]
> SELECT(PostgresMain+0x1b1d) [0x560254bf3aed]
> SELECT(+0xa15cb) [0x56025498f5cb]
> SELECT(PostmasterMain+0x107b) [0x560254b9765b]
> HINT:
> ********** Error **********
> [0x7f19a7ebda5c]
> [0x7f19a7f129b2]
> [0x7f19a7f15665]
> [0x7f19a7f18bc2]
> [0x7f19a7f0f9c0]
> [0x7f19a7f0eda2]
> SQL state: XX000
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20181031/a24e0175/attachment-0001.html>
More information about the pgrouting-dev
