[pgrouting-dev] withPoints(): possible memory leak?
Vicky Vergara
vicky at georepublic.de
Wed Mar 6 10:17:39 PST 2019
On Mon, Mar 4, 2019 at 12:08 PM Clemens Raffler <clemens.raffler at gmail.com>
wrote:
> Dear pgrouting dev team,
> I am hitting a problem with the pgr_withPoints function family and
> wanted to ask you for further guidance and/or advice on how to deal with
> it.
> First I would like to outline the task I am working on:
> I am calculating an origin destination matrix for two sets of points
> (eg. The start_points and end_points), so I am particularly interested
> in retrieving the cost between each startpoint and endpoint using the
> pgr_withPointsCost() function. As a cost factor I am normally using
> precalculated time-costs (seconds) as cost and reverse_cost depicting
> the (real) time a cyclist needs to traverse an edge (I will call those
> costs real_cost). In order to model a cyclists route choice more
> accurately I am introducing a multiplicator for costs on edges that seem
> unpleasant to ride on. Costs on those edges get multiplied by 100 in
> order to retrieve a more realistic routing output. As a result of this
> extra modelling, the pgr_withPointsCost() function aggregates costs
> based on the multiplied cost attributes and do not reflect the initial
> time (eg. real_cost) along the path properly.
> My approach to solve this problem would be to join and aggregate the
> real time costs (which is stored in the input graph table) costs along
> the manipulated routing output involves the use of pgr_withPoints()
> function. In more detail: This function allows me to first store the
> individual path elements of the routes in a result table. Then I would
> like to join the real cost based on the edge attributes of the routing
> output and the input graph table and group by start_pid and end_pid
> while applying sum(real_cost).
> But when changing the pgr_withPointsCost() function to pgr_withPoints()
> function I repeatedly run into some heavy memory leakage (different
> errors that seem to occur in the pgr_withPoints() function). I can give
> you some details on the tests I did:
> 1) Testrun with create table as pgr_withPointsCost() using a graph
> with ~50000 edges, ~4000 Start and End pids: completes without errors
> (although 99% of memory is used).
4000 x 4000 = 16,000,000 rows x (output size 2 BIGINT + 1 FLOAT = 24
Bytes), = 384,000,000 bytes to be kept in memory
They are a lot allready
> 2) Testrun with create table as pgr_withPoints() using a graph with
> ~50000 edges, ~4000 Start and End pids: ERROR std::bad_alloc Hint:
> Working with directed Graph.
4000 x 4000 x (average number of edges in path say 1000) x (output size 2
INTEGERS + 4 BIGINT + 2 FLOAT = 56 Bytes), = 896,000,000,000 bytes to be
kept in memory
huge number, what is the size of your memory?
and remember the computer memory is used in other stuff, like browsers etc
Internally, from the results we have to convert to postgres memory, so add
to that number
like the half used for internal representation and at some point in time
that is being used at least for the result + the graph data.
> 3) Testrun with create table as pgr_withPoints() using a graph with
> ~50000 edges, 100 Start and ~4000 End pids: ERROR invalid memory alloc
> request size 3474796248 Where: SQL-Funktion »pgr_withpoints«
Looks like this is still huge for your computer
> 4) Testrun with create table as pgr_withPoints() using a graph with
> ~50000 edges, 10 Start and ~4000 End pids: completes without errors (50
> sec)
> This looks like your computer can handle it
So if you really need the 4000 x 4000 in one go:
Do as Steve mentions, do a commit after each call, and do the 400 calls
needed
of course it will take 400 * 50 secs to complete.
> I checked the whole issues history of pgrouting on github and found
> tests with way more startpoints (around 80000, but also using
> pgr_withPointsCost() and way more RAM) – maybe it is related:
> https://github.com/pgRouting/pgrouting/issues/694#issuecomment-288035720
> Are you familiar with this kind of behaviour of pgr_withPoints(), which
> ultimately calls just pgr_dijkstra()? Is this a memory leak or do I
> just not have enough RAM (24GB)? Do you have any hints on how to solve
> this issue or do you experience similar problems? I would like to avoid
> cutting the query into smaller chuncs of start_points and iterate over
> them as it is very time inefficient to run such queries.
> I am currently running Postgresql Version 10.3, 64 bit, PostGIS v. 2.4
> and pgrouting 2.6.0, release/2.6.1.59.0 on a Windows 10, 64bit Machine
> with 24GB of RAM. I will also try updating a test system to the current
> postgres, postgis and pgrouting versions and run the query again.
> I would be glad if you could have a look into this.
> Best regards,
> Clemens
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20190306/4227777d/attachment.html>
More information about the pgrouting-dev
