[pgrouting-dev] GSoC 2020 - Depth First Search and Sequential Vertex Coloring for pgRouting - Community Bonding Report Week 3 (Week [-1] Report)
Ashish Kumar
ashishkr23438 at gmail.com
Sat May 23 10:18:18 PDT 2020
Hello everyone,
As I had already started coding from this week, so this is my first weekly
report.
Public Repository: [1]
Project Wiki: [2]
*Coding Period Week [-1] Report (Community Bonding Week 3)*
*(May 18th - May 24th)*
- *What did I complete this week?*
- I started coding my first function named pgr_depthFirstSearch in a
branch named pgr_depthFirstSearch [3] in my forked repository.
- Added all the required files for the implementation of this
function - C, C++, SQL code, and the files required for the documentation
and tests.
- Added the function name in the configuration.conf file and the
signatures in the pgrouting--3.0.0.sig file.
- Made a pull request #34 to the gsoc-ashish branch of the
GSoC-pgRouting repository [4].
- *What did I plan to do the next week?*
- Currently, the function returns an empty row for every query. So, I
will first transform the data to C++ containers suitable for using with
boost and will try to add the boost functionality to this function.
- *Am I blocked on anything?*
- No, currently I don't have any blocking issue.
*Links:*
- [1] https://github.com/krashish8/GSoC-pgRouting
- [2]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2020-Depth-First-Search-and-Sequential-Vertex-Coloring
- [3]
https://github.com/krashish8/GSoC-pgRouting/tree/pgr_depthFirstSearch
- [4] https://github.com/pgRouting/GSoC-pgRouting/pull/34
Thank you,
Ashish Kumar.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20200523/673519fd/attachment.html>
More information about the pgrouting-dev
