[pgrouting-dev] PostGIS Windows 3.0.2 Bundle for PostgreSQL 13 is on Stackbuilder
Regina Obe lr at pcorp.us
Thu Oct 15 00:22:34 PDT 2020
I've just put on EDB Stackbuilder the PostGIS 3.0.2 windows installer for
PostgreSQL 13 so you should see a Spatial Extensions section now
You can also find installers and binaries on OSGeo download
https://download.osgeo.org/postgis/windows/pg13/
As mentioned earlier, this set has newer libraries than the PostGIS 3.0.2 of
older versions.  I do plan on the next micro to have all PostgreSQL versions
using these newer GDAL and proj libraries.  Possibly even newer than what is
packaged in these
What is included is as follows:
PostGIS 3.0.2 (includes postgis, postgis_raster, postgis_sfcgal,
postgis_topology, postgis_tiger_geocoder, and address_standardizer
extensions) -  https://postgis.net/2020/08/15/postgis-patches/
  GDAL 3.0.4, Proj 6.3.2, GEOS 3.8.1  (prior PostGIS 3.0.2 releases had proj
5.2.0 and GDAL 2.4.4), MVT support
Ogrfdw 1.0.12 -
https://github.com/pramsey/pgsql-ogr-fdw/releases/tag/v1.0.12
pgRouting 3.1.0 -
https://docs.pgrouting.org/3.1/en/release_notes.html#changelog-3-1-0
pgPointcloud 1.2.1 -
https://github.com/pgpointcloud/pointcloud/releases/tag/v1.2.1
Please report any issues on this mailing list. pgRouting specific issues
should be reported on the pgRouting list (also cc'd here)
Thanks,
Regina
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20201015/2b5796b0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20201015/2b5796b0/attachment-0001.png>
More information about the pgrouting-dev mailing list
