[pgrouting-dev] GSoC 2021 - Week-8 Report: Implement Edge Coloring Algorithm for pgRouting by the Boost Graph Library
Veenit Kumar 123sveenit at gmail.com
Sun Aug 1 21:07:14 PDT 2021
Hello everyone,
This is the report for the Second Coding Period: Week 8 (July 26th - August
1st).
*What did I get done this week?*
    - Refined the pgTap files.
    - Added more pgTap tests to the file `edge-cases.sql`.
    - Made a pull request with all these changes [1].
    - Details can be found here [2].
*What do I plan on doing next week?*
    - Refine the similar commits together and merge them in the main
repository: https://github.com/pgRouting/GSoC-pgRouting.
    - Final fixing and updating of files failing on building according to
new styles.
    - Details of sub-tasks can be found in [2].
*Am I blocked on anything?*
    - No, I am not blocked on anything.
The log of Pull Requests can be found in [3].
The detailed wiki page can be found in [4].
The Public repository I am working on can be found in [5].
[1] https://github.com/pgRouting/GSoC-pgRouting/pull/186
[2]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#week-8-july-26th---august-1st-1
[3]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#log-of-pull-requests
[4]
[5] https://github.com/veenits123/GSoC-pgRouting
Any feedback and suggestions are welcome.
Thanks!
Veenit Kumar
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20210802/9d00cc67/attachment.html>
More information about the pgrouting-dev mailing list
