[pgrouting-dev] Want to contribute to pgrouting
Riya Singh rsingh99mysteryfan at gmail.com
Thu Feb 4 05:56:46 PST 2021
Thank you for the help, I am going through the workshops and documentation
of pgRouting.
The problems which I am facing is related to postgresql database setup.
In the readme file its mentioned:
*createdb mydatabase
psql mydatabase -c "CREATE EXTENSION pgrouting CASCADE"*
In the documentation
http://docs.pgrouting.org/latest/en/pgRouting-installation.html its
createdb routing
psql routing -c 'CREATE EXTENSION PostGIS'
psql routing -c 'CREATE EXTENSION pgRouting'
CREATE EXTENSION postgis;CREATE EXTENSION pgrouting;
    I am bit confused regarding this. Can you please expalin the steps in
the order they should be exexcuted.
On Mon, Feb 1, 2021 at 7:25 AM Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Riya,
> Nice to hear you are interested in pgRouting and GSoC!
> It's hard to guess what you are confused about with the setup, so you had
> to explain ore in detail.
> I would also recommend you to do the latest pgRouting workshop:
> https://workshop.pgrouting.org/
> Best regards,
> Daniel
> On Mon, 1 Feb 2021 at 02:01, Riya Singh <rsingh99mysteryfan at gmail.com>
> wrote:
>> Hi everyone,
>> I am Riya Singh a 3rd year computer science undergraduate and I
>> would like to contribute to this project as a part of gsoc 2021. I have
>> read the gsoc 2021 guidelines and also tried setting up the project locally
>> on my system. I use Ubuntu 20.04 and I have installed postgresql and
>> postgis and also compiled the project locally. But I am a bit confused
>> about database setup. CAn someone please guide what instructions to run
>> because there are multiple instructions mentioned in the wiki and the
>> documentation page.
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: https://georepublic.info
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20210204/823c40f4/attachment.html>
More information about the pgrouting-dev mailing list
