[pgrouting-dev] Ist there a chance to provide pgRouting extension 2.6.x or 3.1.x as rpm packages released for SLES12 SP5 and SLES15 SP2
Kämpf, Heiko (OWL-IT)
h.kaempf2 at owl-it.de
Wed Jan 27 02:11:49 PST 2021
Dear Devrim Gündüz,
many thanks for your statement about providing pgRouting extensions.
As we could see, also postGIS rpm's have been provided for postgreSQL11, 12 and 13 within SLES15, SLES 15 SP1 and SLES15 SP2 repositories, yesterday.
Currently we are running potgreSQL 10 and 11 together with postGIS 30 and pgRouting 2.6.3 (our own rpm build from your souce code files)
So it might make sense to think about a possible update to our environment, since postGIS 3.x ist also now available within SLES15.
From the point of view of a postgreSQL developer, does it make sense to run SLES15 SP2 instead of SLES12 SP5, now that postGiS and pgRouting is available
on the offivial download sites, to insure possible support from your team and to be save about possible implemention of new functions to our environment.
Many thanks
Kind regards
Heiko
-----Ursprüngliche Nachricht-----
Von: pgrouting-dev <pgrouting-dev-bounces at lists.osgeo.org> Im Auftrag von Devrim Gündüz
Gesendet: Mittwoch, 27. Januar 2021 02:51
An: pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
Betreff: Re: [pgrouting-dev] Ist there a chance to provide pgRouting extension 2.6.x or 3.1.x as rpm packages released for SLES12 SP5 and SLES15 SP2
(PostgreSQL RPM packager speaking)
On Thu, 2021-01-21 at 06:40 +0000, Kämpf, Heiko (OWL-IT) wrote:
> as far as we could see, there doesn't seem to be any pgRouting
> extension rpm packages available at
> https://pgrouting.org/download.html, that is released for SUSE Linux
> Enterprise Server.
> Is there a chance to provide rpm packages, released for SLES12 SP5 or
> SLES15 SP2, in the next time?
> If not, can you recommend what kind of source code version can be
> used, when runnig Linux SLES12 SP5.
SLES 12 is too old to compile newer versions of pgRouting. However I just pushed pgRouting 3.1.3 and 3.0.5 RPMs to the official PostgreSQL ZYPP repository at https://zypp.postgresql.org . To use the repo, please follow the instructions at :
https://zypp.postgresql.org/howtozypp/
Let me know if you have issues/questions.
Regards,
Devrim Gündüz
Open Source Solution Architect, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
More information about the pgrouting-dev
