[pgrouting-dev] GSoC 2021 - Week-1 Report: Implement Edge Coloring Algorithm for pgRouting by the Boost Graph Library
Veenit Kumar
123sveenit at gmail.com
Sat Jun 12 03:48:32 PDT 2021
Hello everyone,
This is the report for the First Coding Period: Week1 ( June 7th - June
13th ).
*What did I get done this week?*
- Started working on the *pgr_edgeColoring* function.
- Dummy placements of all the files that I need to create during the
GSoC period.
- Checked the code after committing using command: *bash
tools/scripts/code_checker.sh coloring*.
- Updated *CMakeLists.txt* for* sql, src, doc, docqueries* files.
- Learned about *license_check*, *News_check*, *shell_check*,
*signature_check*, etc.
- Learned how to use terminal and GitHub Action to check the error while
building files.
- Made a pull request with all these changes [1].
- Details can be found here [2].
*What do I plan on doing next week?*
- Fix all the Bugs and Errors getting on the building and compiling of
files during Week-1.
- Design *boost::edge_coloring()*.
- Create the necessary class wrapper for the Boost function.
- Process the data with the Boost Function.
- Details of sub-tasks can be found in [2].
*Am I blocked on anything?*
- No, I have no issues.
The log of Pull Requests can be found in [3].
The detailed wiki page can be found in [4].
The Public repository I am working on can be found in [5].
[1] https://github.com/pgRouting/GSoC-pgRouting/pull/169
[2]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#week-1-june-7th---june-13th-1
[3]
https://github.com/pgRouting/pgrouting/wiki/GSoC-2021-Implement-Edge-Coloring-Algorithm-for-pgRouting-by-the-Boost-Graph-Library#log-of-pull-requests
[4]
[5] https://github.com/veenits123/GSoC-pgRouting
Any feedback and suggestions are welcome.
Thanks!
Veenit Kumar
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20210612/92b95c86/attachment.html>
More information about the pgrouting-dev
