[pgrouting-dev] pgRouting version 3.2.0 release
Ashish Kumar
ashishkr23438 at gmail.com
Tue May 25 08:27:34 PDT 2021
Hello pgRouting community,
The pgRouting Team is pleased to announce the release of pgRouting version
3.2.0
The latest release is available at [1]
To see all issues & pull requests closed by this release see the Git closed
milestone for 3.2.0 on Github. [2]
*Important to packagers:*
The minimum boost version is now 1.56, to be used with C++11
Boost version starting from 1.75 requires C++14
*Build*
- #1850: Change Boost min version to 1.56
- Removing support for Boost v1.53, v1.54 & v1.55
*New experimental functions*
- pgr_bellmanFord(Combinations)
- pgr_binaryBreadthFirstSearch(Combinations)
- pgr_bipartite
- pgr_dagShortestPath(Combinations)
- pgr_depthFirstSearch
- Dijkstra Near
- pgr_dijkstraNearCost
- pgr_dijkstraNear(One to Many)
- pgr_dijkstraNear(Many to One)
- pgr_dijkstraNear(Many to Many)
- pgr_dijkstraNear(Combinations)
- pgr_dijkstraNearCost(One to Many)
- pgr_dijkstraNearCost(Many to One)
- pgr_dijkstraNearCost(Many to Many)
- pgr_dijkstraNearCost(Combinations)
- pgr_edwardMoore(Combinations)
- pgr_isPlanar
- pgr_lengauerTarjanDominatorTree
- pgr_makeConnected
- Flow
- pgr_maxFlowMinCost(Combinations)
- pgr_maxFlowMinCost_Cost(Combinations)
- pgr_sequentialVertexColoring
*New proposed functions*
- Astar
- pgr_aStar(Combinations)
- pgr_aStarCost(Combinations)
- Bidirectional Astar
- pgr_bdAstar(Combinations)
- pgr_bdAstarCost(Combinations)
- Bidirectional Dijkstra
- pgr_bdDijkstra(Combinations)
- pgr_bdDijkstraCost(Combinations)
- Flow
- pgr_boykovKolmogorov(Combinations)
- pgr_edgeDisjointPaths(Combinations)
- pgr_edmondsKarp(Combinations)
- pgr_maxFlow(Combinations)
- pgr_pushRelabel(Combinations)
- pgr_withPoints(Combinations)
- pgr_withPointsCost(Combinations)
*To update your database:*
Download the packaged version from your operating system, and use this
command in the database:
ALTER EXTENSION pgrouting UPDATE TO "3.2.0";
[1]. https://github.com/pgRouting/pgrouting/releases/latest
[2].
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.2.0%22
<https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.2.0%22>
Regards,
pgRouting Team.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20210525/0a41e1cb/attachment.html>
More information about the pgrouting-dev
