[pgrouting-dev] Help us test out Weblate
Regina Obe lr at pcorp.us
Thu Jan 6 15:47:08 PST 2022
We have Weblate installed on OSGeo infra
At
https://weblate.osgeo.org
For a trial run I'm using our PostGIS workshop
You can login with your LDAP credentials and then I can grant you rights to
the postgis-workshop project.
If I set this up right - commits should show up after an hour or so after
each commit on the below links.
English: https://postgis.net/workshops/en/postgis-intro/
Japanese:  https://postgis.net/workshops/ja/postgis-intro/
German: https://postgis.net/workshops/de/postgis-intro/
Spanish: https://postgis.net/workshops/es/postgis-intro/
Italian: https://postgis.net/workshops/it/postgis-intro/
And you should see your commit show here:
https://github.com/postgis/postgis-workshops
here is an example Sandro did -
https://github.com/postgis/postgis-workshops/commit/f3b1f810a9c25d2889c2216b
62d4843a44544858
My plan is after we are done with some kicking of tires, we will switch
PostGIS docs from transifex to weblate.
For others who want to try it on their projects, let me know I can show you
what little I know about the topic :)
Thanks,
Regina
More information about the pgrouting-dev mailing list
