[pgrouting-dev] pgRouting version 3.4.1, 3.4.0 and version 3.3.5, 3.3.4 release
Ashish Kumar ashishkr23438 at gmail.com
Tue Oct 18 11:56:42 PDT 2022
Hello pgRouting community,
*The pgRouting Team is pleased to announce the release of pgRouting
versions 3.4.1, 3.4.0 and 3.3.5, 3.3.4*
The latest release is available at [1]
The fixes were backported to the previous versions [2]
*To see all issues & pull requests closed by version 3.4.1, see the Git
closed milestone for 3.4.1* [3]
*Issue fixes*
   - #2401: pgRouting 3.4.0 do not build docs when sphinx is too low or
   missing
   - #2398: v3.4.0 does not upgrade from 3.3.3
*To see all issues & pull requests closed by version 3.4.0, see the Git
closed milestone for 3.4.0* [4]
*Issue fixes*
   - #1891: pgr_ksp doesn't give all correct shortest path
*New proposed functions*
   - With points
      - pgr_withPointsVia (One Via)
   - Turn Restrictions
      - Via with turn restrictions
         - pgr_trspVia (One Via)
         - pgr_trspVia_withPoints (One Via)
      - pgr_trsp
         - pgr_trsp (One to One)
         - pgr_trsp (One to Many)
         - pgr_trsp (Many to One)
         - pgr_trsp (Many to Many)
         - pgr_trsp (Combinations)
      - pgr_trsp_withPoints
         - pgr_trsp_withPoints (One to One)
         - pgr_trsp_withPoints (One to Many)
         - pgr_trsp_withPoints (Many to One)
         - pgr_trsp_withPoints (Many to Many)
         - pgr_trsp_withPoints (Combinations)
      - Topology
      - pgr_degree
   - Utilities
      - pgr_findCloseEdges (One point)
      - pgr_findCloseEdges (Many points)
*New experimental functions*
   - Ordering
      - pgr_cuthillMckeeOrdering
   - Unclassified
      - pgr_hawickCircuits
*Official functions changes*
   - Flow functions
      - pgr_maxCardinalityMatch(text)
   - Deprecating pgr_maxCardinalityMatch(text,boolean)
*Deprecated functions*
   - Turn Restrictions
      - pgr_trsp(text,integer,integer,boolean,boolean,text)
      - pgr_trsp(text,integer,float8,integer,float8,boolean,boolean,text)
      - pgr_trspViaVertices(text,anyarray,boolean,boolean,text)
      - pgr_trspViaEdges(text,integer[],float[],boolean,boolean,text)
*To update your database:*
Download the packaged version from your operating system, and use this
command in the database:
ALTER EXTENSION pgrouting UPDATE TO "3.4.1";
[1] https://github.com/pgRouting/pgrouting/releases/latest
[2] https://github.com/pgRouting/pgrouting/releases
[3]
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.4.1%22
[4]
https://github.com/pgRouting/pgrouting/issues?utf8=%E2%9C%93&q=milestone%3A%22Release%203.4.0%22
Regards,
pgRouting Team.
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20221019/c198a1bd/attachment.htm>
More information about the pgrouting-dev mailing list
