[pgrouting-users] Multiple Turn Restrictions?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Aug 19 10:40:39 EDT 2008
http://pgrouting.postlbs.org/ticket/124
Stephen Woodbridge wrote:
> Hi Anton,
> Thank you for your responses and enlightenment. I have updated two wiki
> pages to include some of this additional explanation. When you have a
> chance could you check and make sure I stated thinks correctly and
> completely.
> Added some info on Graphs, Directed, Undirected, and reverse costs.
> http://pgrouting.postlbs.org/wiki/TopologyCreation
> Added info on multiple turn restrictions:
> http://pgrouting.postlbs.org/wiki/ShootingStar
> It seems, like it would be better to add some additional parsing and
> syntax to the rule column to support multiple restriction, rather than
> adding multiple rows. For example, rule could be:
> rule 1 rule 2 rule N
> <edge>[,<edge>][;<edge>[,<edge>]]*
> this would allow any of the following rows
> 4
> 14,4
> 4;12
> 14,4;12
> etc
> Anyway, it is a thought for an improvement. I can open a ticket if you like.
> Best regards,
> -Steve
> Anton Patrushev wrote:
>> You just need to add one more row for that edge.
>> Like this:
>> gid | source | target | cost | x1 | y1 | x2 | y2 | to_cost | rule
>> 11 | 3 | 10 | 2 | 4 | 3 | 4 | 5 | 1000 | 4
>> 11 | 3 | 10 | 2 | 4 | 3 | 4 | 5 | 1000 | 12
>> And then you always need to order your data by gid when you load it to
>> a shortest path function..
>> Anton.
>> On Mon, Aug 18, 2008 at 11:06 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>> Anton,
>>> Ok, that makes sense, but I still do not see how to specify multiple
>>> restrictions for a single edge. For example in the graph below how to I
>>> specify the cost of going from either edge EB(4) or CB(12) to edge DB(11) is
>>> 1000. Both of these turns should be disallowed.
>>> -Steve
>>> PS: Sorry looks like the list is still broken regardless of what email I
>>> send it to.
>>>> Steve,
>>>> Here is the table for your case:
>>>> Edge | Source | Target | Cost | to_cost | rule
>>>> AB | A | B | 1 | 1000 | EB
>>>> BC | B | C | 1 | 1000 | DB
>>>> EB | E | B | 2 | 1000 | BC
>>>> and nothing more.
>>>>> 12 | 3 | 10 | 2 | 4 | 3 | 4 | 5 | 1000 | 14, 4
>>>> This means completely different things.
>>>> For example, you have a graph like this:
>>>> C
>>>> A-------B--------E--------F
>>>> D |
>>>> G
>>>> where edge ids are:
>>>> AB: 10
>>>> BC: 12
>>>> BD: 11
>>>> BE: 4
>>>> EF: 2
>>>> EG: 14
>>>> So, the restriction we have describes a way 14->4->12 (G->E->B->C)
>>>> which is restricted (has cost 1000).
>>>> Anton.
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.postlbs.org
>>>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
