[pgrouting-users] some progress with assign_vertex_id
julien bourgeois
alp.julien.bourgeois at googlemail.com
Thu Aug 21 12:16:42 EDT 2008
> This error is a postgis error generated because you have violated a
> check constraint. I would recommend make a separate database vor each
> dataset you want to load into pgrouting. The code is not currently
> designed to support multiple datasets in a singel database even if they
> are in different schemas.
I got the errors also when my dataset was loaded alone in the database.
In fact, I think the problem comes from the fact that my shapefile contains
3d data (x,y,z -- even though the z values are zeroes). Projecting the shape
in 2d, by removing the z coordinates, fixed it.
Julien
More information about the Pgrouting-users
