[pgrouting-users] Question on using TSP
Stephen Woodbridge woodbri at swoodbridge.com
Tue Oct 28 23:18:04 EDT 2008
How does the TSP code work?
Does it order the nodes by straight line distance between the nodes? or
Does it compute the matrix of possible driving distances between the
nodes and then order that?
I was thinking that if we had N nodes and ran a Dijkstra solution form
with each node as the start point that we could then extract the drive
time costs to each of the other nodes in the solution. So 10 nodes, 10
Dijkstra solutions and we would be able to build the matrix needed for
the TSP solver. I think in an ideal world it would be nice to be able to
handle ~30 nodes, but that may be more an issue of hardware and
parallelism if the software works well.
If the Dijkstra solutions were cached, you could then extract the route
directly from the cache without having to rerun the final solution once
you had the TSP solution.
This is obviously a little more complicated if you assume a directed
graph and turn restrictions.
I built my own TSP solution a while back that orders the node based on
straight line distances. I also prototyped up the above suggestion based
on a Dijkstra solver to feed the TSP.
You can demo my TSP using straight line distances here. It should be
able to handle a fairly large number of nodes:
http://imaptools.com/cgi-bin/tsp.cgi
Just enter a list of cities, you can copy and paste the example is
and/or add your own in the US.
Thanks,
   -Steve
More information about the Pgrouting-users mailing list
