[pgrouting-users] New workshop
    Kai Behncke
    Kai-Behncke at gmx.de
    Wed Apr 22 09:30:55 EDT 2009
Dear users,
as posted some days ago a new workshop (OL 2.7, own osm-data (evaluating them in UMN)) has been finished. You find it at:
http://pgrouting.postlbs.org/wiki/WorkshopOL2.7andOSM
Best regards, Kai Behncke
-------- Original-Nachricht --------
> Datum: Mon, 20 Apr 2009 13:53:44 +0200
> Von: "Kai Behncke" <Kai-Behncke at gmx.de>
> An: pgrouting-users at lists.postlbs.org
> Betreff: Re: [pgrouting-users] PgRouting-Problems with own OSM-data
> Dear users,
> it works now. I made an extract of osm-data (with osmosis) and used then
> osm2pgrouting.
> Everything excellent now (I haven`t got any clue why it didn`t work with
> the shapefile and
> shp2pgrouting).
> I`m going to start the workshop (with describing difficulties and so on)
> today at:
> There will be also a section about the data-problem.
> thank you very much for the support.
> Best regards, Kai
> > Datum: Mon, 20 Apr 2009 09:49:19 +0200
> > An: Anton Patrushev <anton at orkney.co.jp>,
> > Hi Anton,
> > I will put it in the Wiki in a couple of hours.
> > Indeed it`s a really interesting topic because meanwhile I found out
> that
> > there a less failures if I take OSM-XML and use osm2pgrouting (the data
> > with the many, many failures were taken from out of a shape via
> shp2pgsql)  ,
> > I will do some more tests and set it in the wiki in the afternoon.
> > Best regards, Kai
> > > Datum: Mon, 20 Apr 2009 10:50:47 +0900
> > > Von: Anton Patrushev <anton at orkney.co.jp>
> > > Kai, Steve,
> > > It sounds like a very good example of data validation and for sure
> > > will be interesting for other users.
> > > Can someone of you please put it to pgRouting wiki?
> > > Anton.
> > > On Sat, Apr 18, 2009 at 8:25 PM, Kai Behncke <Kai-Behncke at gmx.de>
> wrote:
> > > > Dear users,
> > > > maybe the following screenshot helps fo find out what is wrong with
> my
> > > geodata:
> > > > http://www.selbstverwaltung-bundesweit.de/weird_numbers.png
> > > > The three numbers (blcak on grey backround) show the gid of the
> > > geometry,the source-id and the target-id.
> > > > The blue figure shows the id of the vertices (no dead end) and the
> red
> > > number is the number of the dead-end-vertices.
> > > > As you cann see some are correct and some are not.
> > > > This should happen at SELECT assign_vertex_id('my_table', 0.001,
> > > 'the_geom', 'gid');
> > > > ....but why? I cant`t see the system of that failure?
> > > > Best regards, Kai
> > > >> Datum: Sat, 18 Apr 2009 00:57:30 +0200
> > > >> An: Stephen Woodbridge <woodbri at swoodbridge.com>,
> > > >> Hi Stephen, Hi mailinglist,
> > > >> thank you very much for that hint. With that way I was able to find
> > out
> > > >> that there are far too many "dead ends" in my data, so I think this
> > is
> > > the
> > > >> proof that it`s really a data problem?
> > > >> http://www.selbstverwaltung-bundesweit.de/too_many_dead_ends.png
> > > >> I made this test also with the victoria-data, there everything is
> > > correct.
> > > >> To get a step further I work now with a very small dataset (just 35
> > > >> geometries) (as you can see in the screenshot above) but without
> > > success
> > > >> so far.
> > > >> >If you have a lot of red dots between segments
> > > >> >that should be joined, you probably need to rebuild your vertices
> > tmp
> > > >> >table with a larger tolerance.
> > > >> I did that, I changed 0.001 in
> > > >> SELECT assign_vertex_id('auswahl_os', 0.001, 'the_geom', 'gid');
> > > >> with the values 0.005, 0.01, 0.05, 0.5, 5, 50 and so on
> > > >> The values <50 still show very many "dead ends". If I have higher
> > > values
> > > >> then
> > > >> the amount of vertices in general decreases, so a routing is also
> not
> > > >> possible anymore, you can see it here:
> > > >> http://www.selbstverwaltung-bundesweit.de/not_enough_vertices.png
> > > >> Maybe the following is a hint:
> > > >> If I use
> > > >> with my data I get 54 entries in the vertices_tmp-table.
> > > >> (an extract of the victorie-data (50 geometries) just gives 42
> > entries
> > > in
> > > >> vertices_tmp).
> > > >> What could be the reason that I get so many entries mith my data?
> > > >> What exactly stands the value 0.001 for?
> > > >> I really don`t understand what could be wrong with my geodata :-(
> > > >> Might it be possible that someone would have a look to these 54
> > > geometries
> > > >> (4 eyes see more than two) ??
> > > >> Puh....if I get it I will really write a huge tutorial in the
> > > >> pgrouting-wiki.
> > > >> Best regards, Kai
> > > >> > Datum: Wed, 15 Apr 2009 13:24:21 -0500
> > > >> > Von: Stephen Woodbridge <woodbri at swoodbridge.com>
> > > >> > An: Kai Behncke <Kai-Behncke at gmx.de>
> > > >> > CC: pgrouting-users at lists.postlbs.org
> OSM-data
> > > >> > Kai,
> > > >> > First off you probably need to build some diagnostic tools to
> help
> > > you
> > > >> > understand the problem better, especially to help you determine
> if
> > it
> > > is
> > > >> > a data problem. I find two tools that are easy to build and help
> a
> > > lot.
> > > >> > You can see them in action here:
> > > >> > http://imaptools.com/leaddog/routing/dd.html
> > > >> > Zoom into a city, open the layerswitcher and select "Just the
> > > Streets"
> > > >> > and "Dead Ends"
> > > >> > 1) create a mapfile that displays the street segments from the
> > > routing
> > > >> > database and add this as an optional base layer. You might want
> to
> > > add
> > > >> > color oneway streets a different color, but in general keep the
> > > display
> > > >> > simple and probably single pixel lines. You might label the
> > segments
> > > >> > with their UID so you can go back to the database and query them
> in
> > > >> > detail.
> > > >> > 2) add a column cnt integer to the vertices_tmp table and update
> it
> > > with
> > > >> > the count of segments that reference that node. Maybe something
> > like
> > > >> this:
> > > >> > alter table vertices_tmp add column cnt integer;
> > > >> > update vertices_tmp set cnt=0;
> > > >> > update vertices_tmp set cnt=cnt+1 where streets.source=id;
> > > >> > update vertices_tmp set cnt=cnt+1 where streets.target=id;
> > > >> > Now create a mapfile layer for points and display the
> vertices_tmp
> > > >> > LAYER
> > > >> >    NAME "deadends"
> > > >> >    TYPE POINT
> > > >> >    CONNECTIONTYPE "postgis"
> > > >> >    CONNECTION ...
> > > >> >    DATA ...
> > > >> >    CLASSEXPRESSION "cnt"
> > > >> >    CLASS
> > > >> >      EXPRESSION "cnt=1"
> > > >> >      STYLE
> > > >> >        SYMBOL "circle"
> > > >> >        SIZE 5
> > > >> >        COLOR 255 0 0
> > > >> >      END
> > > >> >    END
> > > >> >    CLASS
> > > >> >      EXPRESSION "cnt>2"
> > > >> >      STYLE
> > > >> >        SYMBOL "circle"
> > > >> >        SIZE 3
> > > >> >        COLOR 0 255 0
> > > >> >      END
> > > >> >    END
> > > >> > END
> > > >> > This will display red dots at dead ends and green dots as good
> > > >> > connections be segments. If you have a lot of red dots between
> > > segments
> > tmp
> > > >> > It is very hard to debug a large black box like a router without
> > > having
> > > >> > some tools that can give you some better insight as to what is
> > going
> > > on.
> > > >> > -Steve
> > > >> Neu: GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate +
> > > >> Telefonanschluss für nur 17,95 Euro/mtl.!*
> http://dslspecial.gmx.de/freedsl-surfflat/?ac=OM.AD.PD003K11308T4569a
> > > >> _______________________________________________
> > > >> Pgrouting-users mailing list
> > > >> Pgrouting-users at lists.postlbs.org
> > > >> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
> > > > Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit
> > > allen: http://www.gmx.net/de/go/multimessenger01
> allen:
Neu: GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate + Telefonanschluss für nur 17,95 Euro/mtl.!* http://dslspecial.gmx.de/freedsl-surfflat/?ac=OM.AD.PD003K11308T4569a
More information about the Pgrouting-users
