[pgrouting-users] [Fwd: Debian Lenny: compatibility
between libcgal-dev and libboost1.35-dev]
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Aug 6 23:52:10 EDT 2009
Hi Daniel,
I understand the issues of sponsorship, but with this lousy world
economy, I would not be holding my breath waiting for some, as sad as
that might be.
So Gaul if I'm not mistaken is used for TSP solver, correct? I just
noticed that there are some solvers in Boost for that:
http://www.google.com/#hl=en&q=boost+tsp
What is CGAL being used for? I'm guessing you are using it for
triangulation of the network nodes using the cost as z so you can then
generate isolines.
-Steve
Daniel Kastl wrote:
> Hi Steve,
> Well, I have a server with Debian but not with pgRouting ... probably
> this is one reason.
> I agree that those dependencies are always a pain. Gaul doesn't come as
> a package, CGAL has a weired license. Actually both of them are just
> used for little parts, so it would be nice to be able to get rid of them
> ... which requires some sort of sponsorship then if there is no
> volunteer (same problem with Windows binaries by the way referencing to
> the discussion on the PostGIS mailing list last night)
> Daniel
> Stephen Woodbridge schrieb:
>> FYI. I sent this off today.
>> Not sure if anyone is using debian/lenny here other than me.
>> I provide an update, if there is any interesting news. I have pgRouting
>> installed on another lenny box using Boost 1.34.1 but there does not
>> appear to be a gaul library for debian. :( So no TSP or DD.
>> -Steve
>> -------- Original Message --------
>> Subject: Debian Lenny: compatibility between libcgal-dev and
>> libboost1.35-dev
>> Date: Thu, 06 Aug 2009 14:02:50 -0400
>> From: Stephen Woodbridge <woodbri at swoodbridge.com>
>> To: Joachim Reichel <joachim.reichel at gmx.de>, Debian Boost Team
>> <pkg-boost-devel at lists.alioth.debian.org>
>> Hello Joachim, and The Boost Packaging Team,
>> I'm running Debian Lenny on an amd64 box and I needed to load
>> libcgal-dev to build pgRouting application. I have been using
>> libboost1.35-dev and see that the packaging is broken if I try to
>> install libcgal-dev.
>> I might be able to backup to libboost 1.34.1, but it would be nice if
>> libcgal would install on the newer version. I realize this might be an
>> issue also with the boost team with respect to package names and
>> version, but maybe you guys can work this out so users like me don't get
>> tripped up by this problem.
>> Thank you both for your efforts, they are all appreciated.
>> Best regards,
>> -Steve
More information about the Pgrouting-users
