[pgrouting-users] directions problem
Stephen Woodbridge woodbri at swoodbridge.com
Thu Feb 12 13:09:01 EST 2009
So set reverse_cost when oneway=1 and cost when oneway=-1
Since you have already messed with the values I would do this now:
-- make sure everything is re-initiallized
UPDATE calle SET to_cost=length(the_geom), reverse_cost=length(the_geom);
-- update the oneway costs
update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=1;
update calle set cost=cost + 1000000 WHERE oneway=-1;
vacuum analyze calle;
Now see how your test route looks.
-Steve
Valeria Muñoz wrote:
> hi Stephen
> i got
> "oneway";"count"
> -1;1451
> 0;21403
> 1;2640
> 0=both ways
> -1=B->A
> 1= A->B
> RG.
> 2009/2/12 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
>     Valeria,
>     What do you get for this query:
>     select distinct oneway, count(*) as count from calle group by
>     oneway, order by oneway;
>     If you have a street A------->B then the oneway flag probable needs
>     3 values. 0 for both ways, 1? for A to B, and maybe 2? for B to A.
>     You need to figure out which values are which.
>     Then you need cost or reverse cost based on the value of oneway.
>     -Steve
>         hi Daniel, thanks for the link..
>          I did the following:
>          * UPDATE calle SET to_cost=length(the_geom),
>         reverse_cost=length(the_geom); *
>         * UPDATE calle SET reverse_cost=reverse_cost + 1000000 WHERE
>         oneway!=0 ,  oneway!=0 are one way streets. *
>         my query:
>         SELECT edge_id as gid,cost as length FROM
>         shortest_path_astar('SELECT gid AS id,source::int4,
>         target::int4, to_cost::double precision as cost,
>         reverse_cost::double precision, x1,y1,x2,y2 FROM
>         calle',3412,3411,false,true)**
>          this do not works 100%, with some street works with others no...
>          I am missing something?
>          RG
>         2009/2/11 Daniel Kastl <kastl at orkney.co.jp
>         <mailto:kastl at orkney.co.jp> <mailto:kastl at orkney.co.jp
>         <mailto:kastl at orkney.co.jp>>>
>            So I guess pgRouting doesn't know that there is a one way street.
>            You might want to read this:
>            http://pgrouting.postlbs.org/wiki/OneWayStreets
>            Daniel
>            Valeria Muñoz schrieb:
>             > HI!!
>             >       I have a little problem with my routing, the best
>         path from
>            A to
>             > B do not respect the traffic direction.
>             > attached image.
>             > please check in the example vicente perez rosales street
>             > Query
>             > rt.gid,rt.the_geom AS tg, AsText(rt.the_geom) AS wkt,
>             > length(rt.the_geom) AS length, calle.gid FROM calle,
>         (SELECT gid,
>             > the_geom FROM dijkstra_sp_delta( 'calle', 3414, 3406,
>         3000) ) as rt
>             > WHERE calle.gid=rt.gid;
>             > RG
>             > _______________________________________________
>             > Pgrouting-users mailing list
>             > Pgrouting-users at lists.postlbs.org
>         <mailto:Pgrouting-users at lists.postlbs.org>
>         <mailto:Pgrouting-users at lists.postlbs.org>>
>             > http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
