[pgrouting-users] directions problem
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 12 14:06:44 EST 2009
Well, maybe I got the from-to sense backwards. Does it always route the
wrong-way down all one-way streets now? If so then, swap the 1 and -1 in
the update statements.
-Steve
Valeria Muñoz wrote:
> Stephen
> does not work, please see the attachment
> RG
> 2009/2/12 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
> So set reverse_cost when oneway=1 and cost when oneway=-1
> Since you have already messed with the values I would do this now:
> -- make sure everything is re-initiallized
> UPDATE calle SET to_cost=length(the_geom),
> reverse_cost=length(the_geom);
> -- update the oneway costs
> update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=1;
> update calle set cost=cost + 1000000 WHERE oneway=-1;
> vacuum analyze calle;
> Now see how your test route looks.
> -Steve
> hi Stephen
> i got
> "oneway";"count"
> -1;1451
> 0;21403
> 1;2640
> 0=both ways
> -1=B->A
> 1= A->B
> RG.
> <mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>>
> Valeria,
> What do you get for this query:
> select distinct oneway, count(*) as count from calle group by
> oneway, order by oneway;
> If you have a street A------->B then the oneway flag probable
> needs
> 3 values. 0 for both ways, 1? for A to B, and maybe 2? for B
> to A.
> You need to figure out which values are which.
> Then you need cost or reverse cost based on the value of oneway.
> -Steve
> hi Daniel, thanks for the link..
> I did the following:
> * UPDATE calle SET to_cost=length(the_geom),
> reverse_cost=length(the_geom); *
> * UPDATE calle SET reverse_cost=reverse_cost + 1000000 WHERE
> oneway!=0 , oneway!=0 are one way streets. *
> my query:
> SELECT edge_id as gid,cost as length FROM
> shortest_path_astar('SELECT gid AS id,source::int4,
> target::int4, to_cost::double precision as cost,
> reverse_cost::double precision, x1,y1,x2,y2 FROM
> calle',3412,3411,false,true)**
> this do not works 100%, with some street works with
> others no...
> I am missing something?
> RG
> 2009/2/11 Daniel Kastl <kastl at orkney.co.jp
> <mailto:kastl at orkney.co.jp>
> <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>
> <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>>>
> So I guess pgRouting doesn't know that there is a one
> way street.
> You might want to read this:
> http://pgrouting.postlbs.org/wiki/OneWayStreets
> Daniel
> Valeria Muñoz schrieb:
> > HI!!
> > I have a little problem with my routing, the best
> path from
> A to
> > B do not respect the traffic direction.
> > attached image.
> > please check in the example vicente perez rosales
> street
> > Query
> > rt.gid,rt.the_geom AS tg, AsText(rt.the_geom) AS wkt,
> > length(rt.the_geom) AS length, calle.gid FROM calle,
> (SELECT gid,
> > the_geom FROM dijkstra_sp_delta( 'calle', 3414, 3406,
> 3000) ) as rt
> > WHERE calle.gid=rt.gid;
> > RG
> > Pgrouting-users mailing list
> > Pgrouting-users at lists.postlbs.org
> <mailto:Pgrouting-users at lists.postlbs.org>
> <mailto:Pgrouting-users at lists.postlbs.org>>
> <mailto:Pgrouting-users at lists.postlbs.org>>>
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
