[pgrouting-users] directions problem
Daniel Kastl kastl at orkney.co.jp
Thu Feb 12 18:19:19 EST 2009
Hi Valeria,
When I saw your first screenshot I already guessed that the first
segment seems to be the problem, but you already could confirm this.
What if you try it with Shooting* function once. It routes from link to
link and not from node to node. (So you need to use link ID's as start
and end in the function.)
Daniel
Valeria Muñoz schrieb:
> I found my problem, the problem is the first segment, from the
> beginning. Query does not consider the first segment, so I took the
> gid of the segment and obtained the information for route instructions.
> As a result of the query do not delivery me the first segment (in some
> cases)  not consider if is one-way street.
> so, now my problem is the first segment. how can i bind to the
> function to return the first segment informacion for the route?
> please see the atachment
> RG
> PD:sorry for my english :)
> 2009/2/12 Valeria Muñoz <valemunoz at gmail.com <mailto:valemunoz at gmail.com>>
>     I exchanged values,
>     update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=1;
>     update calle set to_cost=to_cost + 1000000 WHERE oneway=-1;
>     please see the atachment img_01
>     update calle set reverse_cost=reverse_cost + 1000000 WHERE oneway=-1;
>     update calle set to_cost=to_cost + 1000000 WHERE oneway=1;
>     please see the atachment img_02
>     RG
>     2009/2/12 Stephen Woodbridge <woodbri at swoodbridge.com
>     <mailto:woodbri at swoodbridge.com>>
>         Well, maybe I got the from-to sense backwards. Does it always
>         route the wrong-way down all one-way streets now? If so then,
>         swap the 1 and -1 in the update statements.
>         -Steve
>         Valeria Muñoz wrote:
>             Stephen
>              does not work, please see the attachment
>             RG
>             <mailto:woodbri at swoodbridge.com>>>
>                So set reverse_cost when oneway=1 and cost when oneway=-1
>                Since you have already messed with the values I would
>             do this now:
>                -- make sure everything is re-initiallized
>                UPDATE calle SET to_cost=length(the_geom),
>                reverse_cost=length(the_geom);
>                -- update the oneway costs
>             WHERE oneway=1;
>                update calle set cost=cost + 1000000 WHERE oneway=-1;
>                vacuum analyze calle;
>                Now see how your test route looks.
>                -Steve
>                    hi Stephen
>                     i got
>                     "oneway";"count"
>                    -1;1451
>                    0;21403
>                    1;2640
>                      0=both ways
>                    -1=B->A
>                    1= A->B
>                     RG.
>             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>             <mailto:woodbri at swoodbridge.com>>>>
>                       Valeria,
>                       What do you get for this query:
>                       select distinct oneway, count(*) as count from
>             calle group by
>                       oneway, order by oneway;
>                       If you have a street A------->B then the oneway
>             flag probable
>                    needs
>                       3 values. 0 for both ways, 1? for A to B, and
>             maybe 2? for B
>                    to A.
>                       You need to figure out which values are which.
>                       Then you need cost or reverse cost based on the
>             value of oneway.
>                       -Steve
>                           hi Daniel, thanks for the link..
>                            I did the following:
>                            * UPDATE calle SET to_cost=length(the_geom),
>                           reverse_cost=length(the_geom); *
>                           * UPDATE calle SET reverse_cost=reverse_cost
>             + 1000000 WHERE
>                           oneway!=0 ,  oneway!=0 are one way streets. *
>                           my query:
>                                   SELECT edge_id as gid,cost as length
>             FROM
>                           shortest_path_astar('SELECT gid AS
>             id,source::int4,
>                           target::int4, to_cost::double precision as cost,
>                           reverse_cost::double precision, x1,y1,x2,y2 FROM
>                           calle',3412,3411,false,true)**
>                            this do not works 100%, with some street
>             works with
>                    others no...
>                            I am missing something?
>                            RG
>                           2009/2/11 Daniel Kastl <kastl at orkney.co.jp
>             <mailto:kastl at orkney.co.jp>
>                    <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>
>             <mailto:kastl at orkney.co.jp> <mailto:kastl at orkney.co.jp
>             <mailto:kastl at orkney.co.jp>>>
>             <mailto:kastl at orkney.co.jp>>>>>
>                              So I guess pgRouting doesn't know that
>             there is a one
>                    way street.
>                              You might want to read this:
>              http://pgrouting.postlbs.org/wiki/OneWayStreets
>                              Daniel
>                               > HI!!
>                               >       I have a little problem with my
>             routing, the best
>                           path from
>                              A to
>                               > B do not respect the traffic direction.
>                               > attached image.
>                               > please check in the example vicente
>             perez rosales
>                    street
>                               > Query
>                               > rt.gid,rt.the_geom AS tg,
>             AsText(rt.the_geom) AS wkt,
>                               > length(rt.the_geom) AS length,
>             calle.gid FROM calle,
>                           (SELECT gid,
>                               > the_geom FROM dijkstra_sp_delta(
>             'calle', 3414, 3406,
>                           3000) ) as rt
>                               > WHERE calle.gid=rt.gid;
>                               > RG
>             _______________________________________________
>                               > Pgrouting-users mailing list
>                               > Pgrouting-users at lists.postlbs.org
>             <mailto:Pgrouting-users at lists.postlbs.org>
>             <mailto:Pgrouting-users at lists.postlbs.org>>
>             <mailto:Pgrouting-users at lists.postlbs.org>>>
>             <mailto:Pgrouting-users at lists.postlbs.org>>>>
>              http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
