[pgrouting-users] directions problem
Stephen Woodbridge woodbri at swoodbridge.com
Sat Feb 14 12:04:25 EST 2009
Valeria,
           C
A-------->B
You need to look at the azimuth of the A->B and compare it to the
azimuth of B->C, if the difference is around 0.0 then you are continuing
straight ahead, if the difference is around +-90.0 you are turn right or
left.
You also have to be careful with segments that have a lot of curvature,
like exit ramps, because if you take the azimuth of the start and end
points it might not be what you want, you might want to compute the
azimuth points 1 and 2 for the start end and points numpoints-1,
numpoints for the end of the segment.
-Steve
Valeria Muñoz wrote:
> hi daniel
>   i did try with Shooting*  and WORKS!!! .. thanks thanks!!... now my
> next problem :) i am using azimuth() for instructions(turn left right
> etc..) but i do not how use it, can you help me please?
> RG
> Query :
> SELECT azimuth(startpoint(the_geom),endpoint(the_geom)) as azimuth from
> calle where gid = ".$id_gid."
> I read in a foro about azimuth() and this says that the result i have to
> multiply by 57.29577951. The result is the angle. Now How i know if the
> user have to turn left or rigth ..etc?, exist some algoritm? or function?
> RG
> 2009/2/12 Daniel Kastl <kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>
>     Hi Valeria,
>     When I saw your first screenshot I already guessed that the first
>     segment seems to be the problem, but you already could confirm this.
>     What if you try it with Shooting* function once. It routes from link to
>     link and not from node to node. (So you need to use link ID's as start
>     and end in the function.)
>     Daniel
>     Valeria Muñoz schrieb:
>      > I found my problem, the problem is the first segment, from the
>      > beginning. Query does not consider the first segment, so I took the
>      > gid of the segment and obtained the information for route
>     instructions.
>      > As a result of the query do not delivery me the first segment (in
>     some
>      > cases)  not consider if is one-way street.
>      > so, now my problem is the first segment. how can i bind to the
>      > function to return the first segment informacion for the route?
>      > please see the atachment
>      > RG
>      > PD:sorry for my english :)
>      > 2009/2/12 Valeria Muñoz <valemunoz at gmail.com
>     <mailto:valemunoz at gmail.com> <mailto:valemunoz at gmail.com
>     <mailto:valemunoz at gmail.com>>>
>      >     I exchanged values,
>      >     update calle set reverse_cost=reverse_cost + 1000000 WHERE
>     oneway=1;
>      >     update calle set to_cost=to_cost + 1000000 WHERE oneway=-1;
>      >     please see the atachment img_01
>     oneway=-1;
>      >     update calle set to_cost=to_cost + 1000000 WHERE oneway=1;
>      >     please see the atachment img_02
>      >     RG
>      >     2009/2/12 Stephen Woodbridge <woodbri at swoodbridge.com
>     <mailto:woodbri at swoodbridge.com>
>     <mailto:woodbri at swoodbridge.com>>>
>      >         Well, maybe I got the from-to sense backwards. Does it always
>      >         route the wrong-way down all one-way streets now? If so then,
>      >         swap the 1 and -1 in the update statements.
>      >         -Steve
>      >             Stephen
>      >              does not work, please see the attachment
>      >             RG
>     <mailto:woodbri at swoodbridge.com>>>>
>      >                So set reverse_cost when oneway=1 and cost when
>     oneway=-1
>      >                Since you have already messed with the values I would
>      >             do this now:
>      >                -- make sure everything is re-initiallized
>      >                UPDATE calle SET to_cost=length(the_geom),
>      >                reverse_cost=length(the_geom);
>      >                -- update the oneway costs
>      >             WHERE oneway=1;
>      >                update calle set cost=cost + 1000000 WHERE oneway=-1;
>      >                vacuum analyze calle;
>      >                Now see how your test route looks.
>      >                -Steve
>      >                    hi Stephen
>      >                     i got
>      >                     "oneway";"count"
>      >                    -1;1451
>      >                    0;21403
>      >                    1;2640
>      >                      0=both ways
>      >                    -1=B->A
>      >                    1= A->B
>      >                     RG.
>     <mailto:woodbri at swoodbridge.com> <mailto:woodbri at swoodbridge.com
>     <mailto:woodbri at swoodbridge.com>>>>>
>      >                       Valeria,
>      >                       What do you get for this query:
>      >                       select distinct oneway, count(*) as count from
>      >             calle group by
>      >                       oneway, order by oneway;
>      >                       If you have a street A------->B then the oneway
>      >             flag probable
>      >                    needs
>      >                       3 values. 0 for both ways, 1? for A to B, and
>      >             maybe 2? for B
>      >                    to A.
>      >                       You need to figure out which values are which.
>      >                       Then you need cost or reverse cost based on the
>      >             value of oneway.
>      >                       -Steve
>      >                           hi Daniel, thanks for the link..
>      >                            I did the following:
>      >                            * UPDATE calle SET
>      >                           reverse_cost=length(the_geom); *
>      >                           * UPDATE calle SET
>      >             + 1000000 WHERE
>      >                           oneway!=0 ,  oneway!=0 are one way
>     streets. *
>      >                           my query:
>      >                                   SELECT edge_id as gid,cost as
>     length
>      >             FROM
>      >                           shortest_path_astar('SELECT gid AS
>      >             id,source::int4,
>      >                           target::int4, to_cost::double precision
>     as cost,
>      >                           reverse_cost::double precision,
>     x1,y1,x2,y2 FROM
>      >                           calle',3412,3411,false,true)**
>      >                            this do not works 100%, with some street
>      >             works with
>      >                    others no...
>      >                            I am missing something?
>      >                            RG
>      >                           2009/2/11 Daniel Kastl
>      >             <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>
>     <mailto:kastl at orkney.co.jp> <mailto:kastl at orkney.co.jp
>     <mailto:kastl at orkney.co.jp>>>
>     <mailto:kastl at orkney.co.jp>> <mailto:kastl at orkney.co.jp
>      >             <mailto:kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>>>
>     <mailto:kastl at orkney.co.jp>>>>>>
>      >                              So I guess pgRouting doesn't know that
>      >             there is a one
>      >                    way street.
>      >                              You might want to read this:
>      >              http://pgrouting.postlbs.org/wiki/OneWayStreets
>      >                              Daniel
>      >                               > HI!!
>      >                               >       I have a little problem with my
>      >             routing, the best
>      >                           path from
>      >                              A to
>      >                               > B do not respect the traffic
>     direction.
>      >                               > attached image.
>      >                               > please check in the example vicente
>      >             perez rosales
>      >                    street
>      >                               > Query
>      >                               > rt.gid,rt.the_geom AS tg,
>      >             AsText(rt.the_geom) AS wkt,
>      >                               > length(rt.the_geom) AS length,
>      >             calle.gid FROM calle,
>      >                           (SELECT gid,
>      >                               > the_geom FROM dijkstra_sp_delta(
>      >             'calle', 3414, 3406,
>      >                           3000) ) as rt
>      >                               > WHERE calle.gid=rt.gid;
>      >                               > RG
>      >             _______________________________________________
>      >                               > Pgrouting-users mailing list
>      >                               > Pgrouting-users at lists.postlbs.org
>     <mailto:Pgrouting-users at lists.postlbs.org>
>     <mailto:Pgrouting-users at lists.postlbs.org>>
>     <mailto:Pgrouting-users at lists.postlbs.org>>>
>     <mailto:Pgrouting-users at lists.postlbs.org>>>>
>     <mailto:Pgrouting-users at lists.postlbs.org>>>>>
>      http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
