[pgrouting-users] osm2pgrouting import problem
Daniel Kastl kastl at orkney.co.jp
Sun Jul 12 19:46:31 EDT 2009
Hi Vladislav,
It's nice to hear that you found a solution for this problem.
Would you mind to share your solution (for example by providing a
patch), so other users can also profit from your work? I think you would
help a lot of people who are not able to modify the source code (which
doesn't need to be because they turn off their brain ;-)
Daniel
Vladislav Shikhov schrieb:
> I've made some trivial patches for osm2pgrouting, so now it takes
> about 4 hours to import whole Russia in to DB on 2 cores 2.3 Ghz
> Athlon &1 Gb memory. Switch on you brain, it rather simple.
> On Sun, Jul 12, 2009 at 3:59 PM, Kai Behncke<Kai-Behncke at gmx.de> wrote:
>> Dear users,
>> I tried it as well with the Germany-osm-data (600 MB) on a pc with
>> 4 processors, 4 GB RAM and 7GB Swap), but it failed after 14 hours.
>> I trief then to load in single counties (Bundesländer). Always the first one works
>> but after that (e.g. first one is "Hamburg", second one "Bremen") only nodes are inserted (and no ways). Is this a known error/issue.
>> What would you recommend to get All the data of one country in a database?
>> Thank you very much, Kai
>> -------- Original-Nachricht --------
>>> Datum: Mon, 29 Jun 2009 09:35:45 +0900
>>> Von: Daniel Kastl <kastl at orkney.co.jp>
>>> An: pgrouting-users at lists.postlbs.org
>>> Betreff: Re: [pgrouting-users] osm2pgrouting import problem
>>> Hi Eike,
>>> You probably run into this issue: http://pgrouting.postlbs.org/ticket/140
>>> If you can try it with a smaller dataset for testing and it worked, then
>>> this is the case. If it still doesn't work then please let us know.
>>> The original author of osm2pgrouting said he's currently working on this
>>> issue as time allows.
>>> Daniel
>>> PS: Once I tried a little larger dataset I just increased my SWAP
>>> partition and it worked then, but I don't know how large the German data
>>> is. It's not a nice solution anyway.
>>> Eike Lüders schrieb:
>>>> Hello everybody!
>>>> I've got a problem with osm2pgrouting.
>>>> I downloaded the osm file for germany from here:
>>>> http://download.geofabrik.de/osm/europe/germany.osm.bz2
>>>> If I try to run osm2pgrouting on it now by typing
>>>> ./osm2pgrouting -file germany.osm -conf mapconfig.xml -dbname routing
>>>> -user postgres -passwd postgres -clean
>>>> into the shell it gives me the following information, but nothing
>>>> happes (the db information above are correct!).
>>>> There is no error message or something like that.
>>>> I hope anybody know how to solve this problem.
>>>> host=127.0.0.1 user=postgres dbname=routing port=5432 password=postgres
>>>> connection success
>>>> Trying to load config file mapconfig.xml
>>>> Trying to parse config
>>>> SE for <configuration>
>>>> SE for <type>
>>>> SE for <class>
>>>> class name = motorway
>>>> class id = 101
>>>> class id = 101 name = motorway added to type name=highway
>>>> SE for <class>
>>>> class name = motorway_link
>>>> class id = 102
>>>> class id = 102 name = motorway_link added to type name=highway
>>>> SE for <class>
>>>> class name = motorway_junction
>>>> class id = 103
>>>> class id = 103 name = motorway_junction added to type name=highway
>>>> SE for <class>
>>>> class name = trunk
>>>> class id = 104
>>>> class id = 104 name = trunk added to type name=highway
>>>> SE for <class>
>>>> class name = trunk_link
>>>> class id = 105
>>>> class id = 105 name = trunk_link added to type name=highway
>>>> SE for <class>
>>>> class name = primary
>>>> class id = 106
>>>> class id = 106 name = primary added to type name=highway
>>>> SE for <class>
>>>> class name = primary_link
>>>> class id = 107
>>>> class id = 107 name = primary_link added to type name=highway
>>>> SE for <class>
>>>> class name = secondary
>>>> class id = 106
>>>> class id = 106 name = secondary added to type name=highway
>>>> SE for <class>
>>>> class name = tertiary
>>>> class id = 107
>>>> class id = 107 name = tertiary added to type name=highway
>>>> SE for <class>
>>>> class name = residential
>>>> class id = 107
>>>> class id = 107 name = residential added to type name=highway
>>>> SE for <class>
>>>> class name = living_street
>>>> class id = 108
>>>> class id = 108 name = living_street added to type name=highway
>>>> SE for <class>
>>>> class name = service
>>>> class id = 109
>>>> class id = 109 name = service added to type name=highway
>>>> SE for <class>
>>>> class name = track
>>>> class id = 110
>>>> class id = 110 name = track added to type name=highway
>>>> SE for <class>
>>>> class name = pedestrian
>>>> class id = 111
>>>> class id = 111 name = pedestrian added to type name=highway
>>>> SE for <class>
>>>> class name = services
>>>> class id = 112
>>>> class id = 112 name = services added to type name=highway
>>>> SE for <class>
>>>> class name = bus_guideway
>>>> class id = 113
>>>> class id = 113 name = bus_guideway added to type name=highway
>>>> SE for <class>
>>>> class name = path
>>>> class id = 114
>>>> class id = 114 name = path added to type name=highway
>>>> SE for <class>
>>>> class name = cicleway
>>>> class id = 115
>>>> class id = 115 name = cicleway added to type name=highway
>>>> SE for <class>
>>>> class name = footway
>>>> class id = 116
>>>> class id = 116 name = footway added to type name=highway
>>>> SE for <class>
>>>> class name = bridleway
>>>> class id = 117
>>>> class id = 117 name = bridleway added to type name=highway
>>>> SE for <class>
>>>> class name = byway
>>>> class id = 118
>>>> class id = 118 name = byway added to type name=highway
>>>> SE for <class>
>>>> class name = steps
>>>> class id = 119
>>>> class id = 119 name = steps added to type name=highway
>>>> SE for <class>
>>>> class name = unclassified
>>>> class id = 100
>>>> class id = 100 name = unclassified added to type name=highway
>>>> SE for <class>
>>>> class name = road
>>>> class id = 100
>>>> class id = 100 name = road added to type name=highway
>>>> SE for <type>
>>>> SE for <class>
>>>> class name = lane
>>>> class id = 201
>>>> class id = 201 name = lane added to type name=cycleway
>>>> SE for <class>
>>>> class name = track
>>>> class id = 202
>>>> class id = 202 name = track added to type name=cycleway
>>>> SE for <class>
>>>> class name = opposite_lane
>>>> class id = 203
>>>> class id = 203 name = opposite_lane added to type name=cycleway
>>>> SE for <class>
>>>> class id = 204
>>>> class id = 204 name = opposite added to type name=cycleway
>>>> SE for <type>
>>>> SE for <class>
>>>> class name = grade1
>>>> class id = 301
>>>> class id = 301 name = grade1 added to type name=tracktype
>>>> SE for <class>
>>>> class name = grade2
>>>> class id = 302
>>>> class id = 302 name = grade2 added to type name=tracktype
>>>> SE for <class>
>>>> class name = grade3
>>>> class id = 303
>>>> class id = 303 name = grade3 added to type name=tracktype
>>>> SE for <class>
>>>> class name = grade4
>>>> class id = 304
>>>> class id = 304 name = grade4 added to type name=tracktype
>>>> SE for <class>
>>>> class name = grade5
>>>> class id = 305
>>>> class id = 305 name = grade5 added to type name=tracktype
>>>> SE for <type>
>>>> SE for <class>
>>>> class name = roundabout
>>>> class id = 401
>>>> class id = 401 name = roundabout added to type name=junction
>>>> Trying to load data
>>>> Trying to parse data
>>>> Kind regards
>>>> Eike Lüders
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.postlbs.org
>>>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
>> Neu: GMX Doppel-FLAT mit Internet-Flatrate + Telefon-Flatrate
>> für nur 19,99 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
More information about the Pgrouting-users mailing list
