[pgrouting-users] osm2pgrouting import problem
Kai Behncke
Kai-Behncke at gmx.de
Wed Jul 15 08:22:03 EDT 2009
Hi Vladislay, Hi Stephen,
thank you for your patient help.
Well, I nearly got it.
The following steps:
> 1. svn checkout -r 334
> http://pgrouting.postlbs.org/svn/pgrouting/tools/osm2pgrouting/trunk
> osm2pgrouting
> 2. copy someway a patch from this email into osm2pgrouting just created
> 3. cd into osm2pgrouting
> 4. patch -p0 -i db.patch
> 5. make
.....work well.
I have created a database with pg_routing-functions (so far it has the tables spatial_ref_sys and geometry_columns), but when
I start:
./osm2pgrouting -file your-OSM-XML-File.osm -conf mapconfig.xml -dbname routing -user postgres
I get many error-messages like:
Reference nd=57017125 has no corresponding Node Entry (Maybe Node entry after Reference?)
ERROR: relation "nodes" does not exist
STATEMENT: SELECT id,lon,lat FROM nodes WHERE id ='57017123';
SELECT id,lon,lat FROM nodes WHERE id ='57017123'; ERROR: relation "nodes" does not exist
Reference nd=57017123 has no corresponding Node Entry (Maybe Node entry after Reference?)
STATEMENT: SELECT id,lon,lat FROM nodes WHERE id ='57017127';
LOG: unexpected EOF on client connection
Do I need a special table-structure in the db to start the patch succesfully?
Thank you again, Kai
Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3 -
sicherer, schneller und einfacher! http://portal.gmx.net/de/go/atbrowser
More information about the Pgrouting-users
