[pgrouting-users] latitude longitude of an intersection
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 30 18:43:14 EDT 2009
Valeria,
It would be helpful if you posted the values for your two streets.
st_intersection(), I believe, always returns a geometry collection. This
is because the intersection of two polylines could be a collections of
points and line segments.
You probably want to look at st_dump() which lets you get at the
individual pieces in a collection.
Since your collection is EMPTY it is likely that your two geometries did
not intersect.
-Steve W
Valeria Muñoz wrote:
> Hi daniel
> I have problems with st_intersection function, for any query the
> result is "GEOMETRYCOLLECTION EMPTY"
> my query:
> select AsText(st_intersection('".$geom_ini."','".$geom_ter."'))
> $geom_ini: is the AsText(the_geom) from street A and $geom_ter: is the
> AsText(the_geom) from the street B
> I think I'm completely lost
> RG
> 2009/2/25 Daniel Kastl <kastl at orkney.co.jp <mailto:kastl at orkney.co.jp>>
> Hi Valeria,
> This should be possible with PostGIS.
> Probably you're looking for this function:
> ST_Intersection(geometry, geometry)
> http://postgis.refractions.net/documentation/manual-1.3/ch06.html#id2746133
> Daniel
> Valeria Muñoz schrieb:
>> HI!!
>> i have a questions: can i get the latitude longitude of an
>> intersection?, for example latitude longitude of street1 with street2
>> RG
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.postlbs.org <mailto:Pgrouting-users at lists.postlbs.org>
>> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
