[pgrouting-users] dijkstra_sp result order
Julien-Samuel Lacroix
jlacroix at mapgears.com
Fri Nov 13 15:17:39 EST 2009
I'm trying to use the wrapper functions dijkstra_sp and astar_sp to find
the shortest path between to points. However the order of the output
seems to be wrong.
The following:
SELECT * FROM astar_sp( 'fcmqrouting19', 80, 3667)
returns an un-ordered list of feature (The first line segment in my path
come in third place in the result set for example):
id; gid; the_geom
1; 617; "010...4640"
2; 513; "010...640"
3; 121; "010...4640"
4; 618; "0102...640"
5; 2; "01020...40"
6; 4581;"0102...640"
If I use shortest_path (both astar or dijkstra) functions the order of
gid returned is:
121, 513, 617, 2, 618, 4581
My questions are:
Is this a known bug?
Is there a way to keep the order of my results and still have the "id"
column containing the row number (from 1 to 6 in my example)?
Best regards,
Julien
Mapgears
http://www.mapgears.com/
More information about the Pgrouting-users
