[pgrouting-users] Wrong results at routing by choosing
wrong start/end points?
Kai Behncke
Kai-Behncke at gmx.de
Sat Oct 24 09:35:38 EDT 2009
Hi Marco,
> regarding to http://pgrouting.postlbs.org/wiki/killing_some_bugs
> by calculating the Route twice by changing start and endpoint ist a
> possibility to fix the problem in the triangle-like way at the
> screenshot. But does this also work if the points are many crossings
> away? Dont' I have to compare four results?:
> SELECT gid, the_geom FROM dijkstra_sp_delta(
> '".TABLE."', ".$startEdge['source'].", ".$endEdge['target'].", 3000)
> '".TABLE."', ".$endEdge['source'].", ".$startEdge['target'].", 3000)
> '".TABLE."', ".$startEdge['source'].", ".$startEdge['target'].",
> 3000)
> '".TABLE."', ".$endEdge['source'].", ".$endEdge['target'].", 3000)
...when I created the tutorial I was wondering exactly the same but I
think it can`t be
3000)
or
because then the route calculation is only on one edge (and not between the needed two edges).
Best regards, Kai
So far it runs on
Jetzt kostenlos herunterladen: Internet Explorer 8 und Mozilla Firefox 3.5 -
sicherer, schneller und einfacher! http://portal.gmx.net/de/go/chbrowser
More information about the Pgrouting-users
