[pgrouting-users] Fastest path instead of shortest path
Salet Frank frank.salet at localyse.nl
Wed Aug 4 09:07:50 EDT 2010
Hey guys,
Instead of calculating routes based on shortest path I want to calculate routes based on fastest path. I already have a column with drivetime information (ie in table 'ways' there is a column called 'time' with minutes). Can this be done with the hereunder code and, if yes, what do I need to change? Thank you!
    case 'SPD' : // Shortest Path Dijkstra
      $sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
                   length(rt.the_geom) AS length, ".TABLE.".id
                FROM ".TABLE.",
                    (SELECT gid, the_geom
                        FROM dijkstra_sp_delta(
                            '".TABLE."',
                            ".$startEdge['source'].",
                            ".$endEdge['target'].",
                            3000)
                     ) as rt
                WHERE ".TABLE.".gid=rt.gid;";
      break;
Regards,
Frank
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100804/61ce223a/attachment.html
More information about the Pgrouting-users mailing list
