[pgrouting-users] Adding bike routes to database
Daniel Kastl daniel.kastl at georepublic.de
Thu Aug 12 05:18:01 EDT 2010
Hi Yasir,
Just a question for better understanding:
Are you bike routes user generated (GPS) tracks or are they separate network
data that is just not part of OSM?
If you want to match GPS tracks to an existing road network, there is a
matching.sql with some functions in at least the trunk version of pgRouting.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
2010/8/12 Yasir Shoaib <yasirshoa at gmail.com>
> Hi Daniel,
> Thanks for replying.
> There is the issue of my current bike routes data not being aligned to the
> exiting streets (some differences are present). Also, I am not sure how ways
> can be assigned multiple class id's. The Ontario.osm which was downloaded
> didn't have bike data imported into the pgrouting db, unless I missed
> something. Ontario.osm was downloaded from:
> http://downloads.mapzen.mapzen.cloudmade.com/north_america/canada/ontario
> To get things started, I tried adding the routes and then running the
> search with lower cost assigned to bike routes and higher to other road
> networks but this didn't work as intended. Maybe this is the problem that
> you mention about nodes snapping relating to the high tolerance.
> Although, I am continuing to look into this, based on above do you have any
> suggestions on getting things working?
> Thanks,
> Yasir
> On 11 August 2010 15:34, Daniel Kastl <daniel.kastl at georepublic.de> wrote:
>> Hi Yasir,
>>  I have some bike routes data that I would like to insert to the 'ways'
>>> table in my pgrouting database.
>>> For routing using the added routes, do I need to run assign_vertex_id
>>> again?
>> If you can ensure that you keep a valid topology you don't have to run it
>> again. But probably it's easier to do so.
>>> Also, there are existing streets where the bike routes would be added,
>>> would this be any problem?
>> You might have a problem if nodes get very close to existing ones. they
>> might "snap" if you set your "tolerance" value too high.
>> Also I'm not sure you want to create new roads beside existing ones.
>> Probably you would like to try to match your bike routes with existing
>> roads.
>> Best regards,
>> Daniel
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100812/ca6641b3/attachment.html
More information about the Pgrouting-users mailing list
