[pgrouting-users] Setting the tolerance argument in
assign_vertex_id
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Aug 27 11:31:17 EDT 2010
I think DMTI data is pretty high quality data. I have used it in the
past, granted not for routing but, I never noticed any quality problems.
When I did some of the analysis on other data sets, I created extra
columns on the edges table an did things like mark the edges for all
that had the same source and target nodes and display them in using
mapserver and openlayers and displayed the vertices_tmp table with
deadends as red dots and other nodes as green dots.
Then you can get a quick visualization of the data. Mostly what you want
to look for is to see if deadends fall on connected lines, this
indicates a problem. Look for segments with matching source and target
numbers (color them so they stick out on the map.
If you set the tolerance wrong you will see lots of errors like these.
I also then run pgRouting and overlay that on the maps and can turn on
the reference layers for debugging weird routes.
Look at this:
http://gis.imaptools.com/routing/leaddog/?zoom=10&lat=33.86222&lon=35.51589&layers=B0TTTF&start=35.504139%2033.833331&stop=35.546364%2033.883493&method=STS&lang=eng
Open the layer switcher, zoom in and select "Just the Streets" and "Dead
Ends" and you can see what I mean. "Just the Streets" labels the streets
with the gid of the edge table so you can go investigate a problem.
-Steve
On 8/27/2010 3:44 AM, Dan Putler wrote:
> Thanks a lot Steve, this looks really helpful. I can see that routing
> involves much of the same "art" that geocoding does.
> Based on past experience, I'm not sure that the road network I am
> working with is as clean as you and Daniel appear to assume. I'm
> going to look at the dead-end and other issues tomorrow. I'm also
> wondering if there is any potential benefit of reading the original
> shapefile into GRASS which will attempt to clean it, dumping it back
> into a shapefile from GRASS, and then importing it into PostGIS, or
> does assign_vertex_id basically do the same cleaning that GRASS
> does?
> Dan
> --- On Thu, 8/26/10, Stephen Woodbridge<woodbri at swoodbridge.com>
> wrote:
>> From: Stephen Woodbridge<woodbri at swoodbridge.com> Subject: Re:
>> assign_vertex_id To: "Dan Putler"<putler at yahoo.com> Cc: "pgRouting
>> list"<pgrouting-users at lists.osgeo.org> Received: Thursday, August
>> 26, 2010, 8:55 PM Dan,
>> I think that picking a number around 0.5 to 1 meter should be fine
>> for that data. In general it is unlikely that you will have nodes
>> that are NOT connected but that close together.
>> You can also do some analysis of the results like this, after you
>> run assign_vertex_id():
>> alter table vertices_tmp add column cnt int; update vertices_tmp
>> set cnt = (select count(*) from "<edge_table>" where
>> vertices_tmp.id=target or vertices_tmp.id=source); select cnt as
>> connections, count(*) from vertices_tmp group by cnt order by cnt;
>> This will analyze the connectedness of you network.
>> connections 1 - dead ends 2 - segments connected but only an
>> intersection if different names 3+ - intersections
>> If you run assign_vertex_id() with different tolerance values and
>> then run this analysis as your tolerance gets too big you will see
>> a shift of these numbers to the smaller end which is bad.
>> Another important analysis you check is:
>> select count(*) from "<edge_table>" where target=source;
>> this count should be zero unless you have zero length segments in
>> your data and you can check that with:
>> select gid, st_length(the_geom) from "<edge_table>" where
>> target=source;
>> These are a good way to learn about your data.
>> -Steve
>> On 8/26/2010 8:37 PM, Dan Putler wrote:
>>> Thanks Steve, but I do need a bit of a follow on I
>> think, and
>>> probably provide a bit more explanation.
>>> I'm using a DMTI CanMap routing layer for BC that
>> started out in
>>> NAD83 geographic, which I converted to NAD83 UTM Zone
>> 10N via
>>> ogr2ogr, I also shrank it down using a "with"
>> statement in ogr2ogr to
>>> cover only part of the province. After I sent my
>> email, I did a bit
>>> more Google searching and based on a question in the
>> pgRouting forum,
>>> a user using NAVTEQ layers was using a tolerance that
>> worked out to
>>> between 1 and 1.5 meters. Based on this, I set the
>> tolerance to 2
>>> meters, it sounds like I should set the tolerance in
>> assign_vertex_id
>>> to be much smaller (say 0.15 meters, which is just
>> over 5 inches).
>>> In general, is it better to err on the side of too
>> small or too large
>>> a tolerance, or is that a "it depends" question?
>>> Dan
>> Subject: Re:
>> in
>> Cc: "pgRouting
>>>> 26, 2010, 4:27 PM On 8/26/2010 2:51 PM, Dan Putler
>> wrote:
>>>>> Hi,
>>>>> I'm curious how to determine the value of the
>> second
>>>> argument in the
>>>>> function assign_vertex_id(). Most of the
>> examples I
>>>> can find look
>>>>> like:
>>>>> assign_vertex_id('<edge table>', 0.001,
>>>> 'the_geom', 'gid')
>>>>> Most of the examples are based on edge tables
>> that
>>>> have SRIDs that
>>>>> correspond to either WGS84 geographic or some
>> sort of
>>>> US State Plane
>>>>> feet. I'm using data that is using a UTM
>> coordinate
>>>> SRID, so the map
>>>>> units are in meters. My question is whether
>> the map
>>>> units should
>>>>> influence the choice of the second argument to
>> the
>>>> function (which I
>>>>> assume is a tolerance between edges), or
>> should I just
>>>> keep with the
>>>>> value 0.001? Implicitly, I'm asking if the
>> parameter
>>>> is in the map
>>>>> units of the SRID.
>>>> Dan,
>>>> Right units is important.
>>>> When I use data in WGS84 that has at lease 6
>> decimal places then I
>>>> use 0.000001 as the tolerance. What this means if
>> that if the
>>>> distance between two points are less than or equal
>> 0.000001 units
>>>> then they should be considered the same point.
>> 0.000001 degrees ==
>>>> ~5 inches if I did the math right.
>>>> I think there are two issues you need to be aware
>> of:
>>>> 1) units 2) your data and what precision it was
>> built at
>>>> HTH, -Steve
More information about the Pgrouting-users
