[pgrouting-users] Working with Driving Distance
Daniel Kastl
daniel at georepublic.de
Tue Dec 21 20:51:11 EST 2010
Hi Roger,
You're using the "core" function, I think.
You could use the driving_distance wrapper function, which will return you a
polyogon.
For that you need to load this SQL:
https://github.com/pgRouting/pgrouting/blob/master/extra/driving_distance/sql/routing_dd_wrappers.sql
You can also find it in the directory where the other pgRouting SQL files
are.
The function will take these parameters then:
driving_distance(table_name varchar, x double precision, y double precision,
distance double precision, cost varchar, reverse_cost varchar,
directed boolean, has_reverse_cost boolean)
X,Y are the coordinates you take as a center point.
You can take the returned polygon then and do other spatial queries.
Best regards,
Daniel
2010/12/22 Roger André <randre at gmail.com>
> Hi All,
> I need to generate some maps that show all of the road segments that are
> within a certain distance of specific points. I have been able to generate
> some answers using the driving_distance function, but am not sure what to do
> with them. Here's what I get:
> # SELECT * FROM driving_distance('SELECT gid AS id, source, target,
> length::double precision AS cost FROM edges',49,2000,false,false);
> vertex_id | edge_id | cost
> 15 | 9 | 1854.34547361565
> 20 | 104 | 1549.85630678904
> 22 | 68 | 858.367668935802
> 23 | 125 | 1466.02479201359
> 24 | 75 | 801.137871846872
> 25 | 125 | 1169.02817170106
> 26 | 106 | 1296.98197602289
> 48 | 71 | 902.595810873304
> 49 | 106 | 0
> 51 | 74 | 1948.07551810288
> 52 | 75 | 1620.93404864578
> (11 rows)
> These answers seem legit, but I'm not sure what to do with them.
> Ultimately, I need to show both the minimum enclosing polygon that
> "surrounds" all of the road segments, as well as the road segments
> themselves. Can someone please give me some pointers as to what I can do to
> accomplish this?
> Thanks,
> Roger
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20101222/1e10a58c/attachment.html
More information about the Pgrouting-users
