[pgrouting-users] Working with Driving Distance
Roger André
randre at gmail.com
Tue Dec 21 23:49:59 EST 2010
Hi Daniel,
Ubuntu 9.10.
On Tue, Dec 21, 2010 at 8:43 PM, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Roger,
> What OS do you use?
> I haven't run Driving Distance function for a while and recently upgraded
> to a newer version of Ubuntu.
> In my case it says: ERROR: function alphashape(unknown) does not exist
> Might be that something has changed there with the dependent library
> (CGAL), which is used to calculate the polygon.
> I can't remember there was a problem in the past.
> Daniel
> 2010/12/22 Roger André <randre at gmail.com>
>> Ok, so using what I think is the correct SQL syntax, I get a different
>> sort of error:
>> eligibility=# SELECT the_geom FROM driving_distance('edges', 2512140,
>> 7040129, 2000, 'length', 'length', false, false);
>> NOTICE: SRID: 2276
>> NOTICE: Query: SELECT gid, the_geom FROM points_as_polygon('SELECT
>> a.vertex_id::integer AS id, b.x1::double precision AS x, b.y1::double
>> precision AS y FROM driving_distance(''''SELECT gid AS
>> id,source::integer,target::integer, length::double precision AS cost,
>> length::double precision as reverse_cost FROM edges WHERE
>> setsrid(''''''''BOX3D(2510140 7038129, 2514140 7042129)''''''''::BOX3D,
>> 2276) && the_geom '''', (SELECT id FROM
>> find_node_by_nearest_link_within_distance(''''POINT(2512140
>> 7040129)'''',200,''''edges'''')),2000,true,true) a, (SELECT * FROM edges
>> WHERE setsrid(''''BOX3D(2510140 7038129, 2514140 7042129)''''::BOX3D,
>> 2276)&&the_geom) b WHERE a.vertex_id = b.source')
>> ERROR: function find_node_by_nearest_link_within_distance(unknown,
>> integer, unknown) does not exist
>> LINE 1: ...)''::BOX3D, 2276) && the_geom ', (SELECT id FROM find_node_...
>> HINT: No function matches the given name and argument types. You might
>> need to add explicit type casts.
>> QUERY: SELECT a.vertex_id::integer AS id, b.x1::double precision AS x,
>> b.y1::double precision AS y FROM driving_distance('SELECT gid AS
>> setsrid(''BOX3D(2510140 7038129, 2514140 7042129)''::BOX3D, 2276) &&
>> find_node_by_nearest_link_within_distance('POINT(2512140
>> 7040129)',200,'edges')),2000,true,true) a, (SELECT * FROM edges WHERE
>> setsrid('BOX3D(2510140 7038129, 2514140 7042129)'::BOX3D, 2276)&&the_geom) b
>> CONTEXT: PL/pgSQL function "points_as_polygon" line 17 at FOR over
>> EXECUTE statement
>> PL/pgSQL function "driving_distance" line 25 at FOR over EXECUTE statement
>> Still puzzling this one out.
>> On Tue, Dec 21, 2010 at 7:55 PM, Roger André <randre at gmail.com> wrote:
>>> Hi Daniel,
>>> Thanks for your reply. I checked, and it appears that I have that
>>> wrapper function installed. Here is what my pgrouting install dir looks
>>> like:
>>> $ pwd
>>> /usr/local/pgrouting-1.05/extra/driving_distance/sql
>>> $ ll
>>> total 36
>>> drwxr-xr-x 3 15036 users 4096 2010-12-21 15:58 ./
>>> drwxr-xr-x 5 15036 users 4096 2010-12-21 15:58 ../
>>> drwxr-xr-x 2 root root 4096 2010-12-21 15:58 CMakeFiles/
>>> -rw-r--r-- 1 root root 1811 2010-12-21 15:58 cmake_install.cmake
>>> -rw-r--r-- 1 15036 users 134 2010-11-16 18:42 CMakeLists.txt
>>> -rw-r--r-- 1 root root 5540 2010-12-21 15:58 Makefile
>>> -rw-r--r-- 1 15036 users 1757 2010-11-16 18:42 routing_dd.sql
>>> -rw-r--r-- 1 15036 users 3790 2010-11-16 18:42 routing_dd_wrappers.sql
>>> And I did make sure to run both SQL files against the database my roads
>>> are stored in.
>>> 482 psql -d eligibility -f routing_dd.sql
>>> 483 psql -d eligibility -f routing_dd_wrappers.sql
>>> 490 psql -d eligibility -f routing_tsp.sql
>>> 491 psql -d eligibility -f routing_tsp_wrappers.sql
>>> I will review your usage instructions and see if I'm missing anything.
>>> Roger
>>> On Tue, Dec 21, 2010 at 5:51 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>>> Hi Roger,
>>>> You're using the "core" function, I think.
>>>> You could use the driving_distance wrapper function, which will return
>>>> you a polyogon.
>>>> For that you need to load this SQL:
>>>> https://github.com/pgRouting/pgrouting/blob/master/extra/driving_distance/sql/routing_dd_wrappers.sql
>>>> You can also find it in the directory where the other pgRouting SQL
>>>> files are.
>>>> The function will take these parameters then:
>>>> driving_distance(table_name varchar, x double precision, y double
>>>> precision,
>>>> distance double precision, cost varchar, reverse_cost varchar,
>>>> directed boolean, has_reverse_cost boolean)
>>>> X,Y are the coordinates you take as a center point.
>>>> You can take the returned polygon then and do other spatial queries.
>>>> Best regards,
>>>> Daniel
>>>>> Hi All,
>>>>> I need to generate some maps that show all of the road segments that
>>>>> are within a certain distance of specific points. I have been able to
>>>>> generate some answers using the driving_distance function, but am not sure
>>>>> what to do with them. Here's what I get:
>>>>> # SELECT * FROM driving_distance('SELECT gid AS id, source, target,
>>>>> length::double precision AS cost FROM edges',49,2000,false,false);
>>>>> vertex_id | edge_id | cost
>>>>> 15 | 9 | 1854.34547361565
>>>>> 20 | 104 | 1549.85630678904
>>>>> 22 | 68 | 858.367668935802
>>>>> 23 | 125 | 1466.02479201359
>>>>> 24 | 75 | 801.137871846872
>>>>> 25 | 125 | 1169.02817170106
>>>>> 26 | 106 | 1296.98197602289
>>>>> 48 | 71 | 902.595810873304
>>>>> 49 | 106 | 0
>>>>> 51 | 74 | 1948.07551810288
>>>>> 52 | 75 | 1620.93404864578
>>>>> (11 rows)
>>>>> These answers seem legit, but I'm not sure what to do with them.
>>>>> Ultimately, I need to show both the minimum enclosing polygon that
>>>>> "surrounds" all of the road segments, as well as the road segments
>>>>> themselves. Can someone please give me some pointers as to what I can do to
>>>>> accomplish this?
>>>>> Thanks,
>>>>> Roger
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20101221/1b774c1c/attachment.html
More information about the Pgrouting-users
