[pgrouting-users] Shortest Route Search Not Working
Daniel Kastl
daniel.kastl at georepublic.de
Fri Jul 16 01:17:27 EDT 2010
Which Tutorial do you use?
In case you tried Workshop "FOSS4G2007" it's better to take a look at
http://pgrouting.postlbs.org/wiki/WorkshopOL2.7andOSM
Kai Behncke rewrote the workshop because since 2007 a couple of things
changed with OpenLayers. For example there was no 900913 that time.
Daniel
2010/7/16 Yasir Shoaib <yasirshoa at gmail.com>
> Hello,
> I am trying to have routing working for city of Toronto data. But,nothing
> shows up and a problem is seen in the FindNearestEdge() method.
> One example request sent to the routing php is as follows:
> routing.php?startpoint=-8837720.7293944
> 5412947.799546&finalpoint=-8836963.525083
> 5412307.6394342&method=SPD&srid=900913
> My understanding is that projection for the pgRouting database is 4326 and
> for the tiles displayed in OpenLayers<http://pgrouting.postlbs.org/wiki/OpenLayers>it is 900913. (In the code both the html and php projection values are set
> to 900913. However I am not clear as to how to make the projection changes
> -- whether modify the pgRouting database or change OpenLayers<http://pgrouting.postlbs.org/wiki/OpenLayers>HTML page).
> Further details are below
> - The tiles were rendered through generate_tiles.py script of postgis
> database for Toronto routes. I found Ontario.osm and then extracted city of
> Toronto osm data. Then, created the pgRouting database. Now my map displays
> the tiles correctly in 900913 projection.
> - I am not sure but maybe the pgRouting database is 4326 projection,
> because for A* search the x1,y1... are shown in latlng. ...?
> The HTML page is very similar to:
> http://pgrouting.postlbs.org/wiki/Workshop-RoutingRequest Except that
> instead of 54004 projection, I use 9000913 projection.
> The php page is same as
> http://pgrouting.postlbs.org/wiki/Workshop-ClosestEdge Again I have set
> projection to 900913 here.
> Code snippet:
> $sql = "SELECT gid, source, target, the_geom,astext(the_geom),
> distance(the_geom, GeometryFromText?(
> 'POINT(".$lonlat[0]." ".$lonlat[1]<http://pgrouting.postlbs.org/changeset/1>.")',
> 900913)) AS dist
> FROM ".TABLE." WHERE the_geom && setsrid(
> 'BOX3D(".($lonlat[0]-200)."
> ".($lonlat[1] <http://pgrouting.postlbs.org/changeset/1>-200).",
> ".($lonlat[0]+200)." ".($lonlat[1]<http://pgrouting.postlbs.org/changeset/1>+200).")'::box3d,
> 900913)
> ORDER BY dist LIMIT 1";
> The problem is when the php script runs, findNearestEdge() method doesn't
> work and one warning as followed shown:
> PHP Warning: pg_fetch_result(): Unable to jump to row 0 on PostgreSQL
> result index 3 ...
> I am not sure of the problem. Please, if you have ideas let me know.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20100716/61d36359/attachment.html
More information about the Pgrouting-users
