[pgrouting-users] Today in the discussion forum: demo down
Stephen Woodbridge woodbri at swoodbridge.com
Tue Mar 9 00:02:40 EST 2010
Daniel Kastl wrote:
> Hi list,
> If you keep an idea on the discussion forum of pgRouting, you probably
> already read this post: http://pgrouting.postlbs.org/discussion/topic/340
> To keep the demos up and running is really a problem and probably one of
> the first things to be discussed with a new PSC. Because the demos are a
> lot of work to maintain, but they for sure attract a lot of people.
> @Orkney: for me and Anton it became very difficult now to keep demos
> alive, but I have no good idea so far how to solve this issue.
> Daniel
Hi Daniel,
Can you discuss what the issues are with respect to keeping the demos
running? I can think of the following issues:
1) servers are up/down, access to servers might be problematic.
    - one solution is to look for new servers to host the demos
    - we should probably identify space and load requirements, but OSGeo
might be able to help in this area.
2) changes to the code base are breaking the demos
    - probably need to know more about this if that is the case
3) changes to Posgtresql/PostGIS are breaking the demos
    - the demo system should be relatively stable on a constant version
    - we might need access to more version for testing (virtual machines?)
    - we might need to build an automated demo install script to make it
easy to test on more versions.
4) Other reasons?
OK, rereading your email it seems that 1) is the likely issue. We might
want to discuss some of the other potential issues also as part of the
PSC if they are problematic.
-Steve
More information about the Pgrouting-users mailing list
