Fwd: [pgrouting-users] ordering of route edges?
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Nov 29 20:08:53 EST 2010
Madison,
Yeah, the list does not allow attachments. You have to post the image to
a public site and then put the reference url in the email to the list.
I can't really say what is going on in your example. Most of my code
uses modified copies of the wrapper functions to meet my specific needs.
Are you using released wrapper routines? or have you made changes to them?
What happens when you make a shorter route?
Is all your data in decimal degrees or some meter/feet projection?
What did you use for the tolerance value when you ran
assign_vertex_ids(...)?
-Steve
On 11/29/2010 5:36 PM, Madison Shaw wrote:
> (I sent this to the list but it got bounced - I hope you don't mind me
> contacting you directly)
> Hi Steve,
> The query I use within my php script returns a geojson.
> I'm sorry I still don't completely understand why the results don't
> come back in order... I realise that I may need to flip edges due to
> the traversing backwards, but at the moment it looks like I need to
> completely loop through everything to reorder it as well. I have
> attached a jpg of how it actually looks for the start of the route
> with reference to the sql results.
> Also if you are writing these loops is it best to do it in the php script?
> Cheers
> Madison
> On 29 November 2010 19:54, Stephen Woodbridge<woodbri at swoodbridge.com> wrote:
>> A more useful query would be:
>> SELECT gid, astext(the_geom) FROM dijkstra_sp_delta('roads',1,400,0.1)
>> Also in dijkstra you pass vertex nodes 1 and 400 BUT you get back edges in
>> the order of traversal. The tricky part is that the edge is return as loaded
>> and NOT as traversed, so you need to do some checking and flip those
>> segments that were traversed backwards from the disrtion that they were
>> loaded.
>> -Steve W
>> On 11/29/2010 1:46 PM, Madison Shaw wrote:
>>> Hi Daniel,
>>> Thanks for the quick reply, my SQL statement and its results are below
>>> (with pre selected start and finish points for ease of illustrating my
>>> issue)
>>> As you can see, the edge (gid) that we start from '1' is given the id of
>>> 29.
>>> SELECT gid, the_geom FROM dijkstra_sp_delta('roads',1,400,0.1)
>>> Results
>>> id; gid; the_geom
>>> 1;15;"0102 ... B40"
>>> 2;17;"0102 ... B40"
>>> 3;1139;"0102 ... B40"
>>> 4;746;"0102 ... B40"
>>> 5;879;"0102 ... B40"
>>> 6;12;"0102 ... B40"
>>> 7;1133;"0102 ... B40"
>>> 8;9283;"0102 ... B40"
>>> 9;7;"0102 ... B40"
>>> 10;1137;"0102 ... B40"
>>> 11;875;"0102 ... B40"
>>> 12;880;"0102 ... B40"
>>> 13;634;"0102 ... B40"
>>> 14;637;"0102 ... B40"
>>> 15;4;"0102 ... B40"
>>> 16;18;"0102 ... B40"
>>> 17;19;"0102 ... B40"
>>> 18;14;"0102 ... B40"
>>> 19;1143;"0102 ... B40"
>>> 20;1135;"0102 ... B40"
>>> 21;1259;"0102 ... B40"
>>> 22;109;"0102 ... B40"
>>> 23;1129;"0102 ... B40"
>>> 24;1136;"0102 ... B40"
>>> 25;1130;"0102 ... B40"
>>> 26;1131;"0102 ... B40"
>>> 27;1146;"0102 ... B40"
>>> 28;876;"0102 ... B40"
>>> 29;1;"0102 ... B40"
>>> 30;9;"0102 ... B40"
>>> 31;11;"0102 ... B40"
>>> 32;1132;"0102 ... B40"
>>> 33;8759;"0102 ... B40"
>>> 34;1138;"0102 ... B40"
>>> 35;1260;"0102 ... B40"
>>> 36;8;"0102 ... B40"
>>> 37;10;"0102 ... B40"
>>> 38;1128;"0102 ... B40"
>>> 39;1142;"0102 ... B40"
>>> 40;1134;"0102 ... B40"
>>> 41;1147;"0102 ... B40"
>>> 42;16;"0102 ... B40"
>>> 43;13;"0102 ... B40"
>>> 44;1140;"0102 ... B40"
>>> 45;1258;"0102 ... B40"
>>> Cheers
>>> Madison
>>> On 29 November 2010 18:30, Daniel Kastl<daniel at georepublic.de> wrote:
>>>> Hi Madison,
>>>> Could you send me your routing query to see how it looks like?
>>>> Daniel
>>>> 2010/11/30 Madison Shaw<madisonshaw at googlemail.com>
>>>>> Hi There,
>>>>> I was wondering if someone could help me. I have pgrouting working
>>>>> and producing routes using both Dijkstra and AStar, but the edges that
>>>>> are returned by the SQL are in the wrong order... not the order of the
>>>>> edges as you expect to move through the route from start to finish...
>>>>> eg: (using a short example)
>>>>> If I have a route of ten edges, from start edge 1 to finish edge 10 -
>>>>> I would expect the results to be: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 (using
>>>>> the id column that is returned from the sql)
>>>>> However, the results are more like 3, 6, 2, 8, 1, 9, 4, 7, 10, 5.
>>>>> Is this supposed to happen? Is there a way to return the results in
>>>>> the order you traverse through the route?
>>>>> Cheers
>>>>> Madison
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> Georepublic UG& Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
More information about the Pgrouting-users
