[pgrouting-users] Oneway problem
Espen Isaksen
espen.isaksen at gmail.com
Fri Oct 15 08:23:16 EDT 2010
But I think I have understood this correctly then. That is why I did this:
update elveg set cost=length+1000000 where oneway='FT' ;
update elveg set reverse_cost=length+1000000 where oneway='TF'
This should do exactly what you explained.
However, I wonder if this should concern me?
http://pgrouting.postlbs.org/ticket/212
Espen
On Fri, Oct 15, 2010 at 2:08 PM, Ralf Suhr <Ralf.Suhr at itc-halle.de> wrote:
> Hi Espen,
> one edge is defined by to nodes in pgrouting.
> You need to match the definition of oneway street to the edge.
> If the direction of edge and oneway street are the same, then only the
> reverse_cost must be higher. In case direction from edge are opposite to
> oneway street, the reverse_cost become the the cost for driving the oneway
> street.
> Gr
> Ralf
> Am Freitag 15 Oktober 2010 13:34:47 schrieb Espen Isaksen:
>> Hi!
>> I have a feeling there is something I do not understand concerning
>> routing with oneway streets, but after hours of testing and googling I
>> have to ask you guys on this list.
>> I have a street network for Norway in my database and I have added the
>> columns cost and reverse_cost. I have initially set both columns to
>> the value of the length of the geometry.
>> Then I updated cost and reverse cost by this:
>> update elveg set reverse_cost=length+1000000 where oneway='TF' ;
>> I have this sql running shooting star. The sql is from the FOSS4G workshop:
>> SELECT rt.gid, ST_AsGeoJSON(rt.the_geom) AS geojson,
>> length(rt.the_geom) AS length, elveg.gid
>> FROM elveg,
>> (SELECT gid, the_geom
>> FROM shootingstar_sp(
>> 'elveg',
>> 157334,
>> 157165,
>> 10000, 'cost', true, true)
>> ) as rt
>> WHERE elveg.gid=rt.gid
>> What happens is that if I set the cost column high, the route will not
>> travel on this road in both directions. And whatever I set
>> reverse_cost, there is no changes to the route.
>> Do I need to explain pgrouting to use the reverse_cost column? And why
>> is the cost column working both directions?
>> Espen
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users
