[pgrouting-users] Re: Error whith
Daniel Kastl daniel at georepublic.de
Sat Aug 20 03:41:12 EDT 2011
On Fri, Aug 19, 2011 at 11:50 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
> *Hi everybody.
> After compiling pgrouting whith success, i begin my fist test whith the
> shortest_path() function. My data come from open street map. I've insert  it
> in my database whith ./osm2pgrouting.
> But a get an error when i execute this request:
> SELECT * FROM shortest_path('SELECT gid as
> id,source::integer,target::integer,length::double precision as cost FROM
> ways',965,14, false, false);
> ERROR:  Start vertex was not found.
> Do you know where is the problem ?
Start vertex was not found ... that's the problem. You need to have "965"
and "14" in "source" and "target". Maybe you took the road link id (gid).
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110820/ba2b690e/attachment.html
More information about the Pgrouting-users mailing list
