[pgrouting-users] Re: Many errors : function driving_distance does
not exist, shortest_path_astar , tps
Daniel Kastl
daniel at georepublic.de
Mon Aug 22 11:48:48 EDT 2011
Hi Jules,
Here are working examples of your queries:
SELECT * FROM shortest_path_astar(
'SELECT gid AS id,source::integer,target::integer,length::double
precision AS cost,x1,y1,x2,y2 FROM ways',
300,400,false,false
SELECT * FROM driving_distance(
'SELECT gid AS id,source,target,length::double precision AS cost FROM
ways',
300,1.0,false,false
SELECT * FROM tsp(
'SELECT DISTINCT source AS source_id,x1::double precision as
x,y1::double precision AS y FROM ways WHERE source IN(91,35,75,504,254)',
'91,35,75,504,254',75
Best regards,
Daniel
On Tue, Aug 23, 2011 at 12:08 AM, Jules Kouadio <sekedoua at gmail.com> wrote:
> This is all my databse (routing).
> Please look at this.
> 2011/8/22 Jules Kouadio <sekedoua at gmail.com>
>> Hello Danniel. Thanks again for your support. I progress but i have so
>> much to learn.
>> why this error for this 3 request ?*
>> SELECT * from driving_distance('select gid as
>> id,source,target,length::double precision as cost from ways',22777838,0.01);
>> ERROR: function driving_distance ("unknown", integer, numeric) does not
>> exist
>> HINT: No function matches the given name and argument types. You need to
>> add explicit type conversions.
>> *SELECT * FROM shortest_path_astar('select gid as
>> id,source::int4,target::int4,reverse_cost::double precision as
>> reverse_cost,x1,y1,x2,y2 from ways',22,150,false,false);*
>> ERREUR: Error, query must return columns 'id', 'source', 'target' and
>> 'cost'
>> *SELECT * from tsp('select distinct source as source_id,x1::double
>> precision as x,y1::double precision as y from ways where source
>> in(91,35,75,504,254)','91,35,75,504,254',353);*
>> WARNING: stop the connection because of crash of another server process
>> DETAIL: The postmaster has commanded this server process to cancel the
>> transaction
>> Current and leave because another process server left abnormally
>> and there is probably corrupted shared memory.
>> TIP: In a moment you should be able to reconnect to the base of
>> data and restart your order.
>> the server connection was cut off unexpectedly
>> The server may have terminated abnormally before or during
>> processing the request.
>> The server connection was lost. Attempting reset: success / or sometimes
>> not.
>> I don't understand why all thes errors becose shortest_path function run
>> correctly. Exple
>> SELECT * FROM shortest_path('SELECT gid as
>> id,source::integer,target::integer,length::double precision as cost FROM
>> ways',300,400, false, false); give to me :
>> vertex_id | edge_id | cost
>> 300 | 339 | 0.139255214687805
>> 299 | 338 | 0.179544765048058
>> 195 | 337 | 0.203993410356029
>> 63 | 56 | 0.163071365291157
>> 64 | 57 | 0.0210195901922476
>> 13 | 592 | 0.154135925931186
>> 353 | 593 | 0.167432867084967
>> 255 | 594 | 0.0922310799956524
>> 111 | 595 | 0.410249680272814
>> 435 | 596 | 0.323252439058039
>> 400 | -1 | 0
>> (11 lignes)
>> My table "ways" is join.
>> Thanks !
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110823/7a09d86b/attachment.html
More information about the Pgrouting-users
