[pgrouting-users] Re: Many errors : function driving_distance does not exist, shortest_path_astar , tps
Daniel Kastl daniel at georepublic.de
Wed Aug 24 08:38:52 EDT 2011
Hi Jules,
Any argument against using the latest workshop?
The one you try is 4 years old now and uses a very old version of
OpenLayers. I should remove it from the website actually.
Daniel
On Wed, Aug 24, 2011 at 9:25 PM, Jules Kouadio <sekedoua at gmail.com> wrote:
> Hi Daniel.
> For my  table "ways" i follow step by step this tutorial :
> http://www.pgrouting.org/docs/foss4g2007/ch03.html
> but i dont see any map on my web page 06.indexhtml
> Can you please help me and tell me why i have this problem ?
> Thanks .
> 2011/8/22 Daniel Kastl <daniel at georepublic.de>
>> If you want to write some web application, then you can use
>> OpenLayers/GeoExt for example.
>> See the pgRouting workshop: http://workshop.pgrouting.org/ (there will be
>> an updated on released with FOSS4G in September).
>> Instead of PHP (or some other server side coding) you can also use
>> Geoserver  "SQL views":
>> http://docs.geoserver.org/stable/en/user/data/sqlview.html
>> It's a new feature of Geoserver andvery convenient.
>> If you only want to check results you can use QGIS:
>>    - Create a database connection and add the "ways" table as a
>>    background layer.
>>    - Add another layer of the "ways" table but select Build query before
>>    adding it.
>>    - Type for example "gid"  IN ( SELECT gid FROM
>>    dijkstra_sp('ways',5700,6733)) into the SQL where clause field.
>> Hope that helps.
>> Daniel
>> On Tue, Aug 23, 2011 at 1:01 AM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>> Thank you so mutch ! All is running !
>>> I see that my request was not correctly wrotte .
>>> How can i now visualyse all this result on a map (on a  web map server).
>>> Do you have a good tutorial, step by step, whith all details ?
>>> Thanks again
>>>> Hi Jules,
>>>> Here are working examples of your queries:
>>>> SELECT * FROM shortest_path_astar(
>>>>     'SELECT gid AS id,source::integer,target::integer,length::double
>>>> precision AS cost,x1,y1,x2,y2 FROM ways',
>>>>     300,400,false,false
>>>> SELECT * FROM driving_distance(
>>>>     'SELECT gid AS id,source,target,length::double precision AS cost
>>>> FROM ways',
>>>>     300,1.0,false,false
>>>> SELECT * FROM tsp(
>>>>     'SELECT DISTINCT source AS source_id,x1::double precision as
>>>> x,y1::double precision AS y FROM ways WHERE source IN(91,35,75,504,254)',
>>>>     '91,35,75,504,254',75
>>>> Best regards,
>>>> Daniel
>>>> On Tue, Aug 23, 2011 at 12:08 AM, Jules Kouadio <sekedoua at gmail.com>wrote:
>>>>> This is all my databse (routing).
>>>>> Please look at this.
>>>>> 2011/8/22 Jules Kouadio <sekedoua at gmail.com>
>>>>>> Hello Danniel. Thanks again for your support. I progress but i have so
>>>>>> much to learn.
>>>>>> why this error for this 3 request ?*
>>>>>> SELECT * from driving_distance('select gid as
>>>>>> id,source,target,length::double precision as cost from ways',22777838,0.01);
>>>>>> ERROR: function driving_distance ("unknown", integer, numeric) does
>>>>>> not exist
>>>>>> HINT: No function matches the given name and argument types. You need
>>>>>> to add explicit type conversions.
>>>>>> *SELECT * FROM shortest_path_astar('select gid as
>>>>>> id,source::int4,target::int4,reverse_cost::double precision as
>>>>>> reverse_cost,x1,y1,x2,y2 from ways',22,150,false,false);*
>>>>>> ERREUR:  Error, query must return columns 'id', 'source', 'target' and
>>>>>> 'cost'
>>>>>> *SELECT * from tsp('select distinct source as source_id,x1::double
>>>>>> precision as x,y1::double precision as y from ways where source
>>>>>> in(91,35,75,504,254)','91,35,75,504,254',353);*
>>>>>> WARNING: stop the connection because of crash of another server
>>>>>> process
>>>>>> DETAIL: The postmaster has commanded this server process to cancel
>>>>>> the transaction
>>>>>> Current and leave because another process server left abnormally
>>>>>> and there is probably corrupted shared memory.
>>>>>> TIP: In a moment you should be able to reconnect to the base of
>>>>>> data and restart your order.
>>>>>> the server connection was cut off unexpectedly
>>>>>>          The server may have terminated abnormally before or during
>>>>>>          processing the request.
>>>>>> The server connection was lost. Attempting reset: success / or
>>>>>> sometimes not.
>>>>>> I don't understand why all thes errors becose shortest_path function
>>>>>> run correctly. Exple
>>>>>> SELECT * FROM shortest_path('SELECT gid as
>>>>>> id,source::integer,target::integer,length::double precision as cost FROM
>>>>>> ways',300,400, false, false); give to me :
>>>>>>  vertex_id | edge_id |        cost
>>>>>>        300 |     339 |  0.139255214687805
>>>>>>        299 |     338 |  0.179544765048058
>>>>>>        195 |     337 |  0.203993410356029
>>>>>>         63 |      56 |  0.163071365291157
>>>>>>         64 |      57 | 0.0210195901922476
>>>>>>         13 |     592 |  0.154135925931186
>>>>>>        353 |     593 |  0.167432867084967
>>>>>>        255 |     594 | 0.0922310799956524
>>>>>>        111 |     595 |  0.410249680272814
>>>>>>        435 |     596 |  0.323252439058039
>>>>>>        400 |      -1 |                  0
>>>>>> (11 lignes)
>>>>>> My table "ways" is join.
>>>>>> Thanks !
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110824/2ebd1b20/attachment.html
More information about the Pgrouting-users mailing list
