[pgrouting-users] Fwd: page pour aide pgrouting
Frederic Junod frederic.junod at camptocamp.com
Fri Aug 26 07:38:25 EDT 2011
On Fri, Aug 26, 2011 at 10:37 AM, Jules Kouadio <sekedoua at gmail.com> wrote:
>> Hi Danie.
>> You're using ExtJS 4, don't you?
>> This can work but it can be the reason why it doesn't.
>>> Yes i use ExtJS 4 . I'But even if i delete the ExtJS script call line it's does'nt work. Is it also the boudingbox which isn't correctly configured ?
GeoExt is not compatible with ext 4. No problem with Ext 3.4.0
fredj
>> Thanks
>>> Jules.
>>>>> _______________________________________________
>>>>> Pgrouting-users mailing list
>>>>> Pgrouting-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> Georepublic UG & Georepublic Japan
>>>> eMail: daniel.kastl at georepublic.de
>>>> Web: http://georepublic.de
Frédéric Junod
Camptocamp SA
More information about the Pgrouting-users mailing list
