[pgrouting-users] routing_core_smart problem
Worth Lutz wal3 at mindspring.com
Sun Dec 4 18:35:24 EST 2011
As Daniel noted, the function will not work with all types of data.
I cannot remember now but I had to change something in it to make it work
with my data.  I could diff against the original and tell you what if anyone
is interested.
It is a great example though.  It taught me how to use pl/pgsql to solve
problems I was having.
Worth Lutz
  _____
[mailto:pgrouting-users-bounces at lists.osgeo.org] On Behalf Of Daniel Kastl
Sent: Sunday, December 04, 2011 10:39 AM
To: pgRouting users mailing list
Subject: Re: [pgrouting-users] routing_core_smart problem
On Mon, Dec 5, 2011 at 12:28 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
Hi Daniel,
Who wrote the routing_core_smart.sql functions?
Anton
Is there any documentation of them? It would be nice if we had:
Right ... would be nice to have ;-)
I actually just decided to publish the wrapper, because there were several
questions in the past how the pgRouting demo could start the route from/to
the point you clicked.
1. description of the major public entry points and what the arguments
should be.
It even needs an extra table "network_statistics" to work.
But on the other hand it was supposed to be an example of writing a more
complex wrapper function. It's not really a generic function and may not
work with any type of data.
There are probably several possibilities to improve the functions.
Daniel
2. comments in the code that explain what the overview strategy is and/or a
high level pseudocode of how it executes
Thanks,
 -Steve
On 12/2/2011 9:57 PM, Daniel Kastl wrote:
Hi Lutz,
Thank you very much for sharing this information!
I have also created this ticket:
https://github.com/pgRouting/pgrouting-contrib/issues/3
So you're talking about the following two lines?
 * Line 191
https://github.com/pgRouting/pgrouting-contrib/blob/master/wrapper/routing_c
ore_smart.sql#L191
 * Line 205
ore_smart.sql#L205
Best regards,
Daniel
On Sat, Dec 3, 2011 at 4:26 AM, Worth Lutz <wal3 at mindspring.com
<mailto:wal3 at mindspring.com>> wrote:
   Hi all,
   I have found what appears to be a problem in one of the
   routing_core_smart functions.
   In the function locate_point_as_geometry there are two lines which
   call the function geometryfromtext.
   These functions are called when line_substring returns a point.
   In the geometryfromtext function calls, there is no second argument
   for the srid.  This produces a geometry with a "-1" for the srid.
   When I use shootingstar_smart in my script, MapServer fails on
   trying to work with two geometries with different srids.
   Adding the second argument to the geometryfromtext function fixed
   this problem.  The only geometry with the "-1" srid was the one
   created by these function calls.
   I hope this helps someone.
   Worth Lutz
   Pgrouting-users mailing list
   Pgrouting-users at lists.osgeo.org <mailto:Pgrouting-users at lists.osgeo.org>
   http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
Web: http://georepublic.de <http://georepublic.de/>
eMail:  <mailto:daniel.kastl at georepublic.de> daniel.kastl at georepublic.de
Web:  <http://georepublic.de/> http://georepublic.de
  _____
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.1873 / Virus Database: 2102/4656 - Release Date: 12/04/11
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20111204/3af7e48b/attachment.html
More information about the Pgrouting-users mailing list
