[pgrouting-users] pgrouting speed
Charles Galpin cgalpin at lhsw.com
Wed Feb 2 09:04:21 EST 2011
I have seen this mentioned several times, but never got an idea of what a very high ID is? What's very high?
I have not tried this, but have considered using a smaller region initially and if a route is not found, jump to a bigger region and re-query, then perhaps fall back to an even bigger region before failing.  If 90% of your routing will fit into the first region size then in general you will get much faster routing, and in the cases it fails, only slightly slower.
charles
On Feb 2, 2011, at 3:36 AM, Daniel Kastl wrote:
> Hi Emre,
> How large is your network?
> I think you could do it faster, but it depends also on your hardware and you might also be able to make some changes in the postgresql configuration.
> Ride the city for example is using pgRouting and the size of the cities should be comparable to Istanbul:
> http://www.ridethecity.com/
> To improve speed you can check:
> Indices for attributes used in your query
> ID numbering (very high ID's make it slow)
> complicated cost calculation and joins between tables. If you have this, maybe you could pre-calculate some costs.
> In general as less network data you load with your select as faster it is.
> Daniel
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110202/20405788/attachment.html
More information about the Pgrouting-users mailing list
